Metrist plugin
Visualize the health state of your Metrist monitors.
How to add a Metrist data source
In SquaredUp browse to Data Sources > Add data source and search for the data source. Alternatively, browse to Settings > Data Sources > Add data source.
Display Name:
API Key:
Enter an API key for your Metrist account.
By default, Restrict access to this data source? is set to off. The data source can be viewed, edited and administered by anyone. If you would like to control who has access to this data source, switch Restrict access to this data source? to on.
Use the Restrict access to this data source? dropdown to control who has access to the workspace:
If the user is not available from the dropdown, you are able to invite them to the data source by typing in their email address and then clicking Add. The new user will then receive an email inviting them to create an account on SquaredUp. Once the account has been created, they will gain access to the tenant.
Data source access levels
Access Level:
Testing outcomes
Using the Metrist data streams
Health
This data stream allows you to visualize the health state of your Metrist monitors. In the tile editor, filter by the Metrist data source, select the Health data stream and then click Next. Select an object, or select Dynamic selection, and then configure the settings as you wish.
You can visualize the data as health state blocks. SquaredUp will then visualize the health state block as red/green based on the reported problems from Metrist. If the health state block displays as green, there are no problems with the health of your monitors. If the health state block displays as red, there are problems associated with the health of your monitors. Alternatively, you can visualize the data as a table in SquaredUp.
