Solarwinds Orion plugin
Monitor key metrics and states from your SolarWinds environment.
Prerequisites
The Solarwinds data source requires a user account (username and password) to access the Solarwinds API. The user account is created and managed under Settings > All Settings > User Accounts > Manage Accounts in the Solarwinds console. Creating a user with default permissions (i.e. no admin rights) is usually sufficient.
How to add a Solarwinds data source
Configure and deploy an agent
Prerequisites for agents
Make sure the agent is able to make outbound connections on port 443 to SquaredUp (api.squaredup.com), *.amazonaws.com and Microsoft Azure Relay (*.servicebus.windows.net) - this may include firewall rules and proxy server allow lists.
Parameters to replace:
-ApiKey "key"
Mandatory Replace key
where
key
Where
<ServiceName>
Start-Service -Name squpagent
or
Where
<DisplayName>
Add a Solarwinds data source in SquaredUp
Display Name:
Server URL:
Enter the URL to your Solarwinds environment in the following format:
https://server.domain.name
Server Port:
If you don't use the default port 17778, enter your port here. If you use the default port 17778, you don't need to change this field.
Username and Password:
Enter your username and password for your Solarwinds environment.
Agent Group:
Install Sample Dashboards:
Data source access levels
Access Level:
Testing outcomes
Using the Solarwinds data streams
Create a data stream using the configurable data stream (simplest option) see Creating a data stream using a configurable data stream
Write a custom data stream (advanced use) see Writing a custom data stream (advanced users)
Metric
This data stream calls the /SolarWinds/InformationService/v3/Json/Query
endpoint with a pre-set query, and allows you to enter a custom node type and metric.
Scope to a SolarWinds item that supports metrics
Select + Metric from the data stream list
Enter a Node Type, for example:
Nodes
Enter a Metric, for example:
CPULoad
Health State
endpoint with a pre-set query, and allows you to enter a custom node type.
Scope to a SolarWinds item that supports health states
Select + Health State from the data stream list
Nodes
Node Properties
endpoint with a with a dynamic query, and allows you to select the properties that you want returned for each node. This data stream returns a node property, such as a name or the last known value.
Scope to a SolarWinds data source.
Select + Node Properties from the data stream list
Select a Category, for example:
Server
Select a Vendor, for example:
Windows
Select a Machine Type, for example:
Windows 2019 Server
Optionally, select any Additional Properties to return, for example: Contact
Set a Name Filter.
means match anything, for example:%Server%
– will match anything with a name that has Server in it.%Server
– will match anything with a name that ends with Server.Server%
– will match anything with a name that starts with Server.
Click Save.
This data stream is customizable and can be edited to suit your needs from Settings > Advanced > Data Streams. For example, if you want to return memory in bytes, change the shape of the value to bytes.
Node Metrics
endpoint with a with a dynamic query, and allows you to select the metrics that you want to be returned.
Select + Node Metrics from the data stream list
Server
Windows
Windows 2019 Server
Set a Name Filter.
Select a Metric Table from the dropdown, for example: CPU/Memory History
Select a Timestamp Property from the dropdown, for example: Date Time
Select a Value Property from the dropdown, for example: Average Memory Used
Click Save.
Host/Interface/Volume Metrics
These data streams call the /SolarWinds/InformationService/v3/Json/Query
endpoint with a with a dynamic query, and allow you to select the metrics that you want to be returned.
Select + Host Metrics, + Interface Metrics or + Volume Metrics from the data stream list
Select a Value Property from the dropdown, for example: Minimum CPU Load
Click Save
Custom SWQL
This entry point calls the /SolarWinds/InformationService/v3/Json/Query
endpoint, and allows you to enter a custom SWQL query. See SolarWinds: Use SolarWinds Query Language (SWQL) in the Orion Platform
A good starter JSON for this data stream is as follows:
"name": "customSwql",
"dataSourceConfig": {},
"rowPath": ["results"],
"matches": {
"sourceType": { "type": "equals", "value": "SolarWinds Host" }
"metadata": []
SWQL
This is the SWQL query that is performed on the scoped item. It can be added to the dataSourceConfig
like so:
"swql": "SELECT something FROM somewhere WHERE something like something"
