UptimeRobot plugin
Monitor the availability and performance of your services from your UptimeRobot environment.
How to add a UptimeRobot data source
Display Name:
API Token:
Log into your UptimeRobot instance, copy the Read-Only API Key, and paste it in here.
Data source access levels
Access Level:
Click Add.
