Jenkins plugin
This plugin allows you to add a data source that exposes the basic and core Jenkins components for users to visualize. You are able to index:
Projects (formally Jobs)
Controller
Plugins
Views
Folders
How to add a Jenkins data source
Display Name:
Jenkins Server URL:
Enter the URL to the Jenkins API.
Username:
Enter the username for your Jenkins account.
The account must have API access.
Password:
Enter the password for your Jenkins account.
Install Sample Dashboards:
Data source access levels
Access Level:
Testing outcomes
Using the Jenkins data streams
A single sample dashboard is included which utilizes all data streams included with the data source. It is titled Jenkins Activity and shows the status of the builds, data sources, and nodes.
Data streams are installed with the data source:
Plugin Status
Targets the Controller for all installed data sources
Plugins needing updates will be orange
Folder Status (Advanced)
Targets one or more Folders
Can be configured to run a tree query or return selected properties from all available properties
Great for custom properties
Project Status (Simple)
Targets one of more Projects for the status of the project
Returns status of the project, and details about the most recent builds
State matches the underlying project ‘color’
Project Status (Advanced)
Targets one or more Projects
Build Status (Simple)
Targets one or more Projects/Folders for the status of builds
Build Status (Advanced)
Targets one or more Projects (though targeting more than one is not advised)
Great for custom properties and/or very large data sets
Timestamp is always returned along with any other properties you query
Node Status
Targets the Controller to return all nodes and state
Nodes reporting as offline will be orange
Stage Status
Targets pipeline based Projects
Returns completed and in-progress builds
Returns list of stages and their status
Step Status
Returns list of stage steps and their status
Controller Version
Returns controller version, current stable version, and latest version
Returns a health state showing whether the controller is out of date compared to a specific version
Weather Report
Returns weather reports where configured
Health is based on score
View Status (Advanced)
Targets one or more Views
