Configuring an agent for on-premises data sources
This article walks you through the steps for downloading, deploying, configuring and upgrading an agent for on-premises data sources.
An agent is a service that runs on a local machine and connects an internal service to SquaredUp. The agent listens to the queue from SquaredUp and picks up tasks, for example running scripts to provide data that SquaredUp has asked for.
How to check the version of an agent currently installed
Prerequisites
How to deploy an agent
Prerequisites for agents
Parameters to replace:
-ApiKey "key"
Mandatory Replace key
where
key
Where
<ServiceName>
Start-Service -Name squpagent
or
Where
<DisplayName>
You can find the agent version number in the Properties of the SquaredUpCloud.WinAgent.exe executable or in the log files:
On the server running the agent, open the folder where the agent is installed.
Right-click on the SquaredUpCloud.WinAgent.exe executable then Properties then Details.
- File Version shows the version of the agent that is installed.
- Alternatively, you can see the agent version at the top of any of the log files. Log files are located in the
agent\transient\logs
folder.
See Release Notes - Relay Agent
How to upgrade an agent
The upgrade script needs to be run on the Windows machine running the agent.
Go to Settings > Relay and download the latest release of the SquaredUp agent zip file from the download icon under Options for your agent.
On the Windows machine running the agent, extract the downloaded zip file at the same level as (next to) the
agent
folder.How to find the agent folder location or Service name in Properties
Open PowerShell as an administrator and run the following command:
./Install-SQUPAgent.ps1 -upgrade
The upgrade script will stop the agent service.
Make a note of the
ServiceName
for the next step. The upgrade script output shows theDisplayName
followed by theServiceName
in brackets:VERBOSE: Performing the operation "Stop-Service" on target "SquaredUp Cloud Agent (squpagent)".
Start the agent service.
Where
<ServiceName>
or
Where
<DisplayName>
Check that configured data sources are available in the
agent\transient\plugins
folder. The required connectors should be available in theagent\transient\connectors
folder shortly after running the upgrade.Check that dashboards using built-in data streams work as expected.
If you have created any custom data streams (either manually or via configurable data streams) that depend upon the following data sources, you will need to update the
rowpath
and columnname
properties in each data stream to remove the“results."
suffix:SCOM data source
Custom PowerShell data source
VMware data source
Solarwinds data source
For example:
"name": "results.displayName"
would become"name": "displayName"
and
"rowPath": ["results"]
would become"rowPath": []
Once you have checked everything is working, remove the
backup
folder.The
backup
folder is created in case you need to roll-back: You can stop the service, delete or rename the existingagent
folder, rename the backup folder toagent
, and then restart the service.
How to remove an agent
On the server running the agent, locate the SquaredUp agent service you wish to remove.
Services > SquaredUp Cloud Agent.
Right-click Properties and make a note of the Service name and the Path to executable.
If the agent was configured without a suffix (i.e. a single instance of the agent) then the service name will be squpagent. If a suffix was specified when the agent was configured, a version of the suffix (with spaces and other special characters swapped for "-") will be appended to the name.
Copysc.exe delete squpagent
Where
squpagent
is replaced with the service name if it is not simplysqupagent
This will remove the service from Windows.
Finally, delete the agent folder, as referenced in the Path to executable above.
Troubleshooting an agent
An agent's status is shown in SquaredUpSettings > Relay as a green tick, amber exclamation mark, red cross or gray question mark. Hovering over the status will show information about the last connection.
If the agent status is not green:
- Check that the agent service is running (in Services on the server running the agent).
- Check that the API key is correct. In SquaredUp you can see the last 4 digits of the API key in Settings > Relay and compare this with what's in the
appsettings.json
file in the agent folder/agent/transient/logs
. If necessary, you can edit the agent and click Regenerate API Key to get a new key, then copy that into theappsettings.json
file.How to find the agent folder location or Service name in Properties
- Check the agent logs for any connectivity errors. Support may ask you to change the
LogLevel
fromInformation
toDebug
in theappsettings.json
file. - Check SquaredUp for any reported outages: https://squaredup.statuspage.io/
