Prometheus plugin
The data source lets you monitor any metrics from your Prometheus environment using custom PromQL queries.The data source is available as a Cloud data source and also as an on-premises data source.
Note: This data source is of great use in addition to other data sources. It enables you to get different kinds of data and insights about objects that have been indexed by other data sources.
How to add a Prometheus data source
You will only need to configure and deploy an agent if you adding the Prometheus on-premises data source. If you want to add the Prometheus Cloud data source, you only need to follow the steps detailed in Add a Prometheus data source to SquaredUp.
Configure and deploy an agent
Prerequisites for agents
Parameters to replace:
-ApiKey "key"
Mandatory Replace key
where
key
Where
<ServiceName>
Start-Service -Name squpagent
or
Where
<DisplayName>
Enter the URL of your Prometheus instance.
Select one of the following authentication types, used to access your server, from the Query Type field:
None: No authentication is required.
API Token: You must enter the API authentication token in the API Token field.
Basic Authentication: You must enter a Username and Password in the corresponding fields.
Select the agent Group from the list.
This is only required if you are configuring the Prometheus on-premises data source.
Optionally, select Advanced Options to further configure the plugin via the following options:
Import Semantic Conventions compatible labels:
This option is enabled by default. When enabled, the Prometheus Plugin will look for labels defined by Open Telemetry’s Semantic Resource Conventions and it will use those to create objects in the graph which can be used for scoping and targeting.
Import all labels:
Select to create an object in the knowledge graph for each label and value pair you have within Prometheus, these can then be used for scoping and dashboarding.
Ignore Certificate errors:
If you activate this checkbox the data source will ignore certificate errors when accessing the server. This is useful if you have self-signed certificates.
Object Discovery Settings:
Click this button to dynamically create objects within the SquaredUp knowledge graph and display the Object Discovery Settings fields.
Enter the type of object you would like to have created in the left-hand field (for example, Server Disk), and enter the Prometheus labels that should be used to infer that object in the right-hand field (for example, servername and disk). Click Add another object type to add further object and label values.When populated, the Prometheus plugin will scan the time series metrics and create objects for unique pairs of these values, these objects can then be used for scoping and dashboarding.
Data source access levels
Access Level:
Click Add.
Using the Prometheus data streams
Creating a data stream using PromQL (simplest option) see PromQL
Write a custom data stream (advanced use) see Writing a custom data stream (advanced users)
PromQL
This data stream calls the /api/v1/query
endpoint, and allows you to enter a custom query.
In the tile editor, filter by the Prometheus data source, select the PromQL data stream and then click Next.
You can either select the scoped PromQL data stream or the global PromQL data stream.
If you selected the scoped Prom QL data stream, select the objects you want to use and then click Next.
You do not need to do this if you have selected the global PromQL data stream.
Enter a Query, for example:
sum by (instance) (rate(kubedns_probe_dnsmasq_latency_ms_sum[1m])) / sum by (instance) (rate(kubedns_probe_dnsmasq_latency_ms_count[1m]))
Mustache parameters are supported when scoped to an object.
Supports mustache parameters
A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example,
{{timeframe.start}}
will insert the start time based on the timeframe configured within the tile, or{{name}}
will insert the name of the object(s) in scope.This data stream supplies scoped objects individually for mustache parameters. When there are multiple objects in scope this data source will send the query multiple times, once for each object. The results are then displayed together, for example in a single table.
You can use properties of objects and write them in between curly braces e.g
{{name}}
to use them as mustache parameters. Whenever you use mustache parameters, you need to use a scope of objects that contain the property you're referencing.For example, if objects of type "host" have a property called
name
, you can use{{name}}
. This will resolve{{name}}
to the value of the name property of the different "host" objects used in the scope.Scope Objects
When all labels are imported, or the Object Discovery Settings have been configured, Scope Objects can now be passed to a Prometheus Query using
{{{scopedLabels}}}
.As Prometheus uses curly brackets in PromQL, an additional space is needed before and after the triple brackets. You can see an example query below:
Copyrate(rpc_server_duration_milliseconds_sum{ {{{scopedLabels}}} }[5m]) / rate(rpc_server_duration_milliseconds_count{ {{{scopedLabels}}} }[5m])
Ignore Timeframe:
Tick this checkbox if you wish to return a single scalar value rather than a table of results.
Click Save.
Go to Settings > Advanced > Data Streams.
Click Add new Data Stream.
Choose the Data Source this Data Stream is for.
After you've chosen the data source a new field Entry Point appears.
Entry point and code:
What is an entry point?
Each data stream uses an entry point, which can either be global (unscoped) or scoped, and this determines whether the data stream uses the tile scope.
To find out which entry point to select and get code examples for the Code field, see the help below.
Example 1: Using a Prometheus query
Which data stream do I have to select?
Prometheus Query (Unscoped)
Display Name
Mandatory
The internal name of the data stream. Can be used the refer to this data stream in a tile's JSON instead of using the data stream's internal ID.
dataSourceConfig
Parameters
Query | Mandatory
Note: You can't use mustache parameters in the query since it doesn't use the |
Ignore Timeframe | Optional You can add the ![]() The dashboard timeframe is the current timeframe setting for a dashboard. Users can change the dashboard timeframe to see data for a different time span, for example, instead of showing data from "the last 12 hours" it can be changed to show data from "the last 7 days". Tiles can be configured to:
Tip: Indicate with the name of a tile if the tile's timeframe can be changed. For example, naming a tile "Performance during the last week" tells users that this tile always shows data for the last week. Naming a tile just "Performance" indicates to users that changing the dashboard timeframe will change the data. |
Example 2: Get CPU usage for a selected object from a GCP cluster
Note: This Data Stream requires a Google Cloud Platform data source which has to be configured to return information from a cluster.
Prometheus Query (Scoped)
Display Name
Mandatory
dataSourceConfig
Parameters
Query | Mandatory You can use mustache parameters in the query.
![]() A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, This data stream supplies scoped objects individually for mustache parameters. When there are multiple objects in scope this data source will send the query multiple times, once for each object. The results are then displayed together, for example in a single table. You can use properties of objects and write them in between curly braces e.g For example, if objects of type "host" have a property called |
Ignore Timeframe | You can add the ![]() The dashboard timeframe is the current timeframe setting for a dashboard. Users can change the dashboard timeframe to see data for a different time span, for example, instead of showing data from "the last 12 hours" it can be changed to show data from "the last 7 days". Tiles can be configured to:
