SCOM plugin
Monitor your SCOM environment, including Windows Computers, Enterprise Applications and more.
The SCOM data source is for accessing data in your on-premises SCOM environment, see How to add a SCOM data source
The SCOM Managed Instance data source is for accessing data in the PaaS monitoring service. See How to add a SCOM Managed Instance (MI) data source
Configure the agent for a SCOM data source
Why do agents for the SCOM data source need special configuration?
The SquaredUp agent service uses the local system identity by default. SCOM uses Windows authentication which requires at a minimum Network Service or a Domain User account, the agent you use for the SCOM data source needs to have its service identity changed to such an account.
When using a NetworkService account, the computer account the agent is running on must be added to a Read Only Operator Role. If using a domain account for the service, the service account must be added to SCOM in a Read Only Operator role.
Configure and deploy an agent
Prerequisites for agents
Parameters to replace:
-ApiKey "key"
Mandatory Replace key
where
key
is the domain service account Alternatively, in Services > SquaredUp Cloud Agent > Properties select the account on the Log On tab.
Where
<ServiceName>
Start-Service -Name squpagent
or
Where
<DisplayName>
Consider which objects you want to index and set the permissions for the service account accordingly. As the SCOM data source supports SCOM RBAC you can use scoping in the user role for the account in SCOM to control which objects will be indexed.
You need to manually add the service account to the opsmgreader role of the Data Warehouse in the SCOM console see Manually creating the Data Warehouse permissions
Add a SCOM data source in SquaredUp
Display Name:
Agent Group:
SCOM Management Server:
Enter your SCOM management server as a FQDN, for example
server.domain.local
Dashboard Server SCOM Edition URL:
Optional. If you use SquaredUp DS for SCOM, you can enter the URL to your instance. This will create a link from a SCOM object in SquaredUp to the same object in your SquaredUp DS for SCOM.
Enter the URL to the root domain including https, for example:
https://myserver.mydomain/SquaredUp/
What is my SquaredUp DS for SCOM URL?
By default, the URL to your SquaredUp instance is:
http://SquaredUpServer/SquaredUpInstance
SquaredUpServer
is the name of the server where SquaredUp is installed.By default,
SquaredUpInstance
isSquaredUp
. For v5 it isSquaredUpv5
and for v4 . If you gave your SquaredUp instance a different application name when you installed it, use the name you chose.SquaredUpv4
Advanced Settings:
Optionally, select the Advanced Settings check box to display the Custom Classes section, which allows you to retrieve additional classes from SCOM.
Click the Add new custom classes button to display the entry fields.
Enter a name for the additional class in the Class name field. For example,
Windows Computer
Enter / paste the JSON for the class you want to import in the Custom class JSON field. For example:
Copy[
"name":"Import class 'Microsoft.Windows.Computer'",
"classId":"ea99500d-8d52-fc52-b5a5-10dcd1e9d2bd",
"types":[
"className":"Microsoft.Windows.Server.DC.Computer",
"type":"addomaincontroller"
"className":"Microsoft.Windows.Computer",
"type":"host"
"properties":[
"children":[
"name":"Import related class 'Microsoft.Windows.LogicalDevice'",
"classId":"3361982a-7dfd-288d-f48c-e04e85149750",
"types":[
"className":"Microsoft.Windows.LogicalDisk",
"type":"volume"
"className":"Microsoft.Windows.NetworkAdapter",
"type":"interface"
"properties":[
]The properties parameter
The optional properties parameter is a special property that provides a mechanism to add or modify properties from the target class. Here is the basic structure of the properties parameter:
Copy"properties":[
"name":"Parameters",
"as":"monitorUrl",
"XPath":"/Parameters/Parameter[@name='URL']",
"transform":"url"
]Example
To add a new property, simply omit the XPath, jsonPath, and transform options. Here is a functional example that adds the
NetbiosComputerName
field to theWindows Computer
class:Copy[
"types":[
"type":"host"
"properties":[
"name":"NetbiosComputerName",
"as":"netbiosComputerName"
"children":[
"types":[
"type":"volume"
"type":"interface"
"properties":[
Optionally, click the Add another custom class button to add an additional class and enable another line of entry fields.
Example
Here is a functional example of Custom class JSON you can enter to imports the
Web Application Test Web Test Base
class from SCOM:Copy[
"name":"Import class 'Microsoft.SystemCenter.WebApplicationTest.WebTestBase'",
"classId":"8e5cb3e8-3a88-4301-a703-553772fe72dd",
"types":[
"className":"Microsoft.SystemCenter.WebApplicationTest.WebTestBase",
"type":"monitor"
"properties":[
"as":"monitorUrl",
"transform":"url"
"children":[
Data source access levels
Access Level:
Click Add.
The SCOM Managed Instance data source is for accessing data in the SCOM MI PaaS monitoring service. Use the instructions in this section to configure SCOM MI and add the SCOM MI data source to SquaredUp.
If you only have the traditional on-premises SCOM (and have followed the instructions to add the SCOM data source above) and do not have SCOM MI then you do not need to use this section to add the SCOM MI data source.
Configure SCOM Managed Instance in Azure
Log in to the Azure Portal.
Search for
and click on the instance to connect to SquaredUp.Under Reports click the PowerBI tab.
Copy DB Name and DB Host URL. You will use these in the next section adding the data source to SquaredUp.
Click the SquaredUp link at the bottom of the page to login to your SquaredUp organization, and follow the steps in the next section to add the data source.
Add a SCOM Managed Instance data source in SquaredUp
Display Name:
DB Name:
The database name of the SCOM MI data warehouse. This value can be found in the Reports section of the SCOM MI instance.
DB Host URL:
The URL of the SCOM MI database server. This value can be found in the Reports section of the SCOM MI instance. Keep the comma and port after the URL.
Username:
Enter the username of a SQL account to logon to SCOM MI.
The username must have data warehouse reader permissions to access SCOM MI data.
Password:
Enter the password of the SQL account.
Access Level:
Click Add.
How to add a SCOM Managed Instance (MI) On-Premise data source
The SCOM Managed Instance On-Premise data source is for accessing on-premise data in the SCOM MI PaaS monitoring service. Use the instructions in this section to configure SCOM MI On-Premise and add the SCOM MI On-Premise data source to SquaredUp.
Search for
Add a SCOM Managed Instance On-Premise data source in SquaredUp
Display Name:
Agent Group:
DB Name:
DB Host URL:
Username:
Password:
Access Level:
Click Add.
Using the SCOM data streams
Metric
This data stream calls an API endpoint to get metrics from your SCOM instance, and allows you to enter a custom object name, counter name and instance name.
In the tile editor, filter by the SCOM data source, select Metric from the data stream list and then click Next.
Select the objects that you want to use and then click Next.
Enter an Object Name, for example:
LogicalDisk
.Enter a Counter Name, for example: Free Megabytes.
Optionally, enter an Instance Name.
Optionally, enter the Top N number of items you want to see.
Check Sort descending if you want to sort the results descending instead of ascending.
Click Save.
