GitLab plugin
Monitor the CI/CD metrics from your GitLab environment.
How to add a GitLab data source
To create an API token key:
Access a GitLab account with access to the target projects.
Navigate to https://gitlab.com/-/profile/personal_access_tokens.
Ensure the access is at least
read_api
andread_repository
. Please note,read_user
andread_registry
are optional.Click the Create personal access token button.
Copy the provided API token.
Display Name:
Instance URL:
Enter a URL if you wish to use your own instance of GitLab.
If you leave this section blank, https://gitlab.com will be used by default.
API Token:
Paste the API token in here.
Data source access levels
Access Level:
Testing outcomes
Using the GitLab data streams
Data streams are installed with the data source
GQL Query
The GitLab data source allows you to set up configurable data streams for any kind of GQL query. If you need help using GQL, please refer to: GraphQL
Scope to an object that supports a GQL query.
Select + GQL Query from the data stream list.
Enter a Display Name for the new data stream.
Query:
Enter a GQL query.
RowPath:
Optional, focus on results within the GQL query. Target on the array of data that you want to display. For example:
projects.nodes
.Click Save.
This example query shows you how to get the details about the current user, the groups it has access to and the project IDs in those groups.
query{
currentUser{
groups{
nodes
projects {
edges {
node {
id
name
fullName
id
name
id
You’ll need to inform the cloud platform where the rows start. It must be a value returned as an array, such as edges
(in the above example) or nodes
You can use mustache to alter the query with values from the scope.
A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, {{timeframe.start}}
will insert the start time based on the timeframe configured within the tile, or {{name}}
will insert the name of the object(s) in scope.
You can use properties of objects and write them in between curly braces e.g {{name}}
to use them as mustache parameters. Whenever you use mustache parameters, you need to use a scope of objects that contain the property you're referencing.
For example, if objects of type "host" have a property called name
, you can use {{name}}
. This will resolve {{name}}
to the value of the name property of the different "host" objects used in the scope.
