Custom PowerShell plugin
This plugin is one of two available for PowerShell. Make sure to choose the correct version depending on your requirements:
PowerShell plugin: Visualize data from PowerShell scripts (cloud only).
Custom PowerShell plugin: Run user-created PowerShell scripts on Relay Agents.
How to add a Custom PowerShell data source
Configure and deploy an agent
Prerequisites for agents
Parameters to replace:
-ApiKey "key"
Mandatory Replace key
where
key
Where
<ServiceName>
Start-Service -Name squpagent
or
Where
<DisplayName>
Create the PowerShell scripts and store the files on the machine in a folder readable by the agent
Your PowerShell scripts can serve two different functions:
Import script: In case you need to import new objects into SquaredUp, you need an import script. This script contains the definitions for objects and their links in the Knowledge Graph. There can only be one import script per Custom PowerShell data source. Tip: You can add more Custom PowerShell data sources to SquaredUp if you want to use different import scripts, and they can all use the same folder.
Data Stream script: All other scripts are Data Stream scripts. Those scripts contain the different Data Streams you want to use when you are creating tiles for a dashboard.
Import scripts return objects to SquaredUp using the following format:
Import scripts write objects to SquaredUp in the following format:
vertices = @()
edges = @()
Example import script
Information about parameters in the script:
Vertex (vertices create objects in SquaredUp)
name | string – the name of the vertex |
sourceId | string – a unique ID identifying the vertex |
type | string – the high-level type of the vertex Note: A lot of types are already pre-defined in SquaredUp, which means they will be displayed properly with an icon etc. To make sure the type you're using matches with a pre-defined one, use lowercase only, one word without hypens, and the singular form (for example loadbalancer, apidomain, dnsrecord). If your type isn't recognized, you can add it as a custom type, see Types and Custom Types. |
sourceType | string – a type for the vertex pertinent to your specific use-case |
other properties | You can use any other properties of use in your specific use-case |
Edges (edges create links between objects in SquaredUp):
label | string – the type of edge |
inV | string – the sourceId value of the vertex the edge enters |
outV | string – the sourceId value of the vertex the edge leaves |
get-objects.ps1:
vertices = @(Get-CimInstance -Class Win32_LogicalDisk |
? { $_.DriveType -eq 3 } |
[PSCustomObject]@{
name = ('{0} {1}' -f $_.SystemName,$_.Name)
sourceId = ('\\{0}\root\cimv2:Win32_LogicalDisk.DeviceID="{1}" ({2})' -f $_.SystemName,$_.Name,$_.VolumeSerialNumber)
type="storage"
sourceType="volume"
FileSystem = $_.FileSystem
Compressed = $_.Compressed
Size = $_.Size
edges = @()
Data Stream scripts return objects to SquaredUp using the following format:
Data Stream scripts return data as a simple array of objects:
Example Data Stream script
Note: To be able to use the Data Stream script you also need to create a custom Data Stream that calls your Data Stream script. This is done from Settings > Advanced > Data Streams. The format of the result objects of your script needs to match the columns you've defined in the custom Data Stream.
get-diskFreeSpace.ps1:
Param(
[Parameter(Mandatory=$true)]
$scope
$targetObjectsBySourceId = @{}
foreach ($targetObject in $scope) {
$targetObjectsBySourceId[$targetObject.sourceId[0]] = $targetObject
$results = (Get-CimInstance -Class Win32_LogicalDisk |
$sourceId = '\\{0}\root\cimv2:Win32_LogicalDisk.DeviceID="{1}" ({2})' -f
if ($targetObjectsBySourceId.ContainsKey($sourceId)) {
[PSCustomObject]@{
Size = $_.Size
FreeSpace = $_.FreeSpace
return $results
Add a custom PowerShell data source in SquaredUp
Display Name:
Agent Group:
Scripts Directory:
Enter the path to the directory where you store the PowerShell scripts on the machine you deployed the agent on.
Note: The path must be written as an absolute path, for exampleC:\Scripts\SquaredUpCloud
or, if you are using a network share,\\fs01\Scripts\SquaredUpCloud
Import Script:
Optional. If you want to use a script for importing objects into SquaredUp, you can specify that script here by entering its full file name, for exampleget-objects.ps
Note: The import script must be stored in the same directory you defined above.“Only allow signed scripts” check-box:
If you check this box, no unsigned PowerShell scripts will be executed. This applies to all scripts run by the data source, not just the import script.
Data source access levels
Access Level:
Click Add.
If you defined an import script, it will run shortly and the objects will subsequently appear in the dashboard in the new workspace.
4. Add one or more custom Data Streams in SquaredUp.
To be able to use the return data from your PowerShell Data Stream scripts in tiles on dashboards, you need to create custom Data Streams.
Go to Settings > Advanced > Data Streams.
Add a new Data Stream with the following settings:
Display Name This name will be displayed when you are creating tiles on a dashboard and can pick Data Streams. Data source Choose the Custom PowerShell data source. Entry point You can either use a scope of objects (list scope) or not limit the scope to specific objects (no scope).
If you use the list scope, the Data Stream will only be visible when creating a tile that has those objects in its scope. Which objects are included is defined by the
matches
parameter in the Data Stream JSON.You can use all parameters you used for defining vertices in the import script as criteria for which objects to include (e.g. a specific type of object).
Enter the JSON for the Data Stream in the code box.
Format of the JSON for the Data Stream
dataSourceConfig.scriptPath
Defines which script is run by this Data Stream matches
If you selected the entry point "list scope", here you define for which objects the Data Stream will be visible when creating a tile.
metadata
Allows you to customize how the results are displayed in SquaredUp. You can modify which columns are shown as well as their format, for example currencies, dates, and storage units. You can also specify which columns are the label and which are the value for the visualization.
Copy{
"name": "diskSpace",
"dataSourceConfig": {
"scriptPath": "get-diskFreeSpace.ps1"
"matches": {
"sourceType.0": {
"type": "equals",
"value": "volume"
"rowPath": [
"results"
"metadata": [
"name": "results.name",
"displayName": "Name",
"shape": "string"
"name": "results.size",
"displayName": "Disk Size",
"shape": "bytes"
"name": "results.freeSpace",
"displayName": "Free Space",
"shape": "bytes"
