Custom Data Streams
How to add a custom Data Stream
Specific Entry Point Reference
What is a Data Stream?
What is a Custom Data Stream?
A custom data stream is a data stream that you, as an advanced user, can write yourself.
Go to Settings > Advanced > Data Streams.
Click Add new Data Stream.
Choose the Data Source this Data Stream is for.
After you've chosen the data source a new field Entry Point appears.
Entry point and code:
What is an entry point?
Each data stream uses an entry point, which can either be global (unscoped) or scoped, and this determines whether the data stream uses the tile scope.
To find out which entry point to select and get code examples for the Code field, see the help below.
Generic Schema Reference
This section covers parameters that can be used in any entry point. For parameters that are specific to individual entry points see Specific Entry Point Reference
Global entry points can't use specific objects in the matches
parameter. You can identify global entry points by their name, they have "Global", "No Scope" or "Unscoped" added to their name.
There are two possible options for the matches parameter for global entry points:
"matches": "none", | When creating a tile, the Data Stream will be shown as long as no scope is selected. As soon as a scope is selected, the Data Stream will be hidden. |
"matches": "all", | When creating a tile, the Data Stream will be shown as soon as any scope is selected. |
With the matches
parameter you define for which objects the data stream will be shown in SquaredUp. It works like this:
When you configure a tile, you have to choose its scope. If this scope contains objects you specified here in the matches
parameter, the data stream will be shown in SquaredUp under Data Streams. If the scope doesn't contain objects specified here, the data stream will be hidden.
This keeps things clean and simple since you'll only see the data stream when it's relevant for the scope you chose. As a best practice you should limit the data stream to objects that make sense for the specific use case of this data stream.
Format for matches
//If you want to specify only one value of an object property//
"matches": {
"ObjectProperty": {
"type": "equals",
"value": "ValueOfTheObjectProperty"
//If you want to specify multiple values for an object property//
"matches": {
"ObjectProperty": {
"type": "oneOf",
"values": ["ValueOfTheObjectProperty1", "ValueOfTheObjectProperty2", "ValueOfTheObjectProperty3"]
Example for limiting a data stream to objects:
If you are using multiple values for the object property, you can decide if you want the data stream to be visible for objects that match all of the criteria or at least one of the criteria.
Lets say you have two values you want objects to have in order for the data stream to be visible for them:
a
SourceName
property with the valueAppDynamics
(meaning objects that come from the AppDynamics data source)a
type
property with the valueapp
(meaning application objects)
If you want the data stream to be visible only for objects that match both of the criteria, your code would look like this:
"matches": {
"sourceName": {
"type": "equals",
"value": "AppDynamics"
"type": {
"type": "equals",
"value": "app"
If you want the data stream to be visible for objects that match at least one of the criteria, your code would look like this:
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
Note: Defining the matches
parameter is mandatory.
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
Note: If you run into errors when configuring the matches
parameter, check if you're dealing with a global entry point.
Optional, but recommended
The metadata
parameters are used to describe columns in order to tell SquaredUp what to do with them. You can do multiple things with the metadata
parameters:
Specify how SquaredUp should interpret the columns you return and - to an extent - how their content displayed. You do this by giving each column a shape.
Filter out or just hide columns.
Only the columns you define in
metadata
will be returned in the results. This helps you to filter out columns you don't need. If you need the content of a column but don't want to display it, you can use thevisible
parameter.Give columns a nicely readable display name.
Assign a specific role to columns
The role you assign to a column tells SquaredUp the purpose of the column. For example, if you have two different columns that contain numbers, you need to assign the role
value
to the column that contains the actual value you want to use in your visualization.
Note: If you don't specify any metadata, all columns will be returned and SquaredUp will do its best to determine which columns should be used for which purpose. If you're returning pretty simple data, for example just a string and a number, this can work fine. But if you're returning two columns with numbers it gets trickier for SquaredUp to figure out which one is the value and which one is just an ID or some other number.
Parameters:
Tip: Before you start specifying metadata, leave them empty at first and get all the raw data with your new data stream once. In order to do this, finish creating your custom data stream without metadata and create a tile with this data stream. The Table visualization will show you all raw data.
This will give you an overview about all columns and their content and help you decide which columns you need and what their shapes and roles should be. It's also essential for getting the correct column name to reference in the name
parameter.
Use this information to go back to the data stream configuration and specifying the metadata.
name | Mandatory | Enter the name of the column you are referencing here. To find the name of a column, get the data from this data stream once without any metadata. See the tip above for how to do that. You'll see the column name when you hover over the column in the Table. |
displayName | Optional | Here you can give the column a user-friendly name |
shape | Recommended | The shape you assign to a column tells SquaredUp what the column contains (for example, a number, a date, a currency, a URL, etc.). Based on the shape SquaredUp decides how to display this column, for example to display a URL as a clickable link. Note: Please refer to the list of shapes below this table to see available shapes. |
role | Recommended | The role you assign to a column tells SquaredUp the purpose of the column. For example, if you have two different columns that contain numbers, you need to assign the role Note: Please refer to the list of roles below this table to see available roles. |
visible | Optional |
Use this if you need a columns content but don't need to display the column itself. Example: Column A contains the full link to a ticket in your ticket system. Column B contains the ticket ID. You want to use the ticket ID as a label for the link, turning the long URL into a much nicer to read "Ticket 123". This is why you need the content of column B, to assign it as a label for column A. But since the URL is now displayed as the ticket ID, it would be redundant to still display column B. This is why you hide column B with |
Basic types, like:
boolean
,date
,number
,string
Currency types that get displayed with two decimal values and their currency symbol (for example $23,45), like:
currency
(generic currency),eur
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
Utility types, like:
customUnit
url
(will be displayed as a link)
Tip:
If a shape is configurable, you can edit how the shape displays data in SquaredUp.
Many of the data streams in these examples can now be created easily using configurable data streams. The reference information below can also be useful editing data streams, because any data stream created using configurable data streams can be edited from Settings > Data Streams.
Data Stream for Events
Events
Code example:
"name": "customEvents",
"dataSourceConfig": {
"eventTypes": [
"APP_SERVER_RESTART",
"APPLICATION_DEPLOYMENT"
"severities": [
"INFO",
"WARN"
"rowPath": [],
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"metadata": []
Parameters:
| Mandatory The internal name of the data stream. Can be used the refer to this data stream in a tile's JSON instead of using the data stream's internal ID. | |||||||||||||||||||||||||
eventTypes | Optional Enter the names of the event types you want to return. If you don't specify any event types, all event types will be returned. You can find a list of all AppDynamics event types in their API documentation: https://docs.appdynamics.com/display/PRO40/Events+Reference | |||||||||||||||||||||||||
severities | Optional You can filter the returned events by their severity. The possible values are:
If you don't specify any severities, you'll get events of all severities. | |||||||||||||||||||||||||
matches | Optional Note: Defining the With the Format for Copy
Example for limiting a data stream to objects: If you are using multiple values for the object property, you can decide if you want the data stream to be visible for objects that match all of the criteria or at least one of the criteria. Lets say you have two values you want objects to have in order for the data stream to be visible for them:
If you want the data stream to be visible only for objects that match both of the criteria, your code would look like this: Copy
If you want the data stream to be visible for objects that match at least one of the criteria, your code would look like this: Copy
Note: If you run into errors when configuring the Data streams can be either global or scoped:
![]() Global entry points can't use specific objects in the There are two possible options for the matches parameter for global entry points:
metadata | Optional, but recommended The
Note: If you don't specify any metadata, all columns will be returned and SquaredUp will do its best to determine which columns should be used for which purpose. If you're returning pretty simple data, for example just a string and a number, this can work fine. But if you're returning two columns with numbers it gets trickier for SquaredUp to figure out which one is the value and which one is just an ID or some other number. Parameters: Tip: Before you start specifying metadata, leave them empty at first and get all the raw data with your new data stream once. In order to do this, finish creating your custom data stream without metadata and create a tile with this data stream. The Table visualization will show you all raw data.
![]() There are many different shapes you can use for your columns and the list of possible shapes gets expanded constantly:
Tip: Some shapes can be configured. If a shape is configurable, you can edit how the shape displays data in SquaredUp. ![]()
Data Stream for Metrics
Metrics
Code example:
"name": "kpiDatabaseAvailability",
"metric": "KPI|DB Availability",
"scaleFactor": 100
"rowPath": [],
"matches": {
"sourceName": { "type": "equals",
"type": { "type": "equals",
"value": "db"
"metadata": []
Parameters:
metric | Mandatory You need to enter the correct string of the AppDynamics metric here. To find the correct, string, you need to log into your AppDynamics account and open the Metric Browser. Click on one of the metrics to see the full path of the metric. Which part of the metric you have to enter for For applications, tiers, and nodes: For hosts, databases and EUM apps: Enter the bits before and after the last | | |||||||||||||||||||||||||
scaleFactor | Optional You can enter a number to scale the results. The results will be multiplied by the number you entered. This is useful when you want to convert results to percentages. For example, when the result is a number between 0 and 1, you can multiply the result by 100 to get a percentage. | |||||||||||||||||||||||||
Note: You should limit the Data Stream to the objects that have the metric you specified in the | |||||||||||||||||||||||||
Example for a JQL query
This Data Stream returns a list of issues based on the given JQL query.
Tip: When you are using the blocks visualization for a tile that uses this Data Stream, completed issues will be shown as green, all other issues will be gray.
JQL query
Code example:
"name": "projectIssuesAll",
"jql": "project={{key}}&updatedDate>='{{timeframe.startTime}}'"
"rowPath": [],
"matches": {
"type.0": { "type": "equals", "value": "jira project" }
"metadata": [
{ "name": "key", "displayName": "Key", "shape": "string", "role": "id" },
{ "name": "fields.summary", "displayName": "Summary", "shape": "string" },
{ "name": "fields.issuetype.name", "displayName": "Type", "shape": "string" },
{ "name": "fields.priority.name", "displayName": "Priority", "shape": "string" },
{ "name": "fields.status.name", "displayName": "Status", "shape": "string" },
{ "name": "fields.status.statusCategory.name", "displayName": "Status Category", "shape": "string", "visible": false },
{ "name": "fields.resolution.name", "displayName": "Resolution", "shape": "string" },
{ "name": "fields.project.name", "displayName": "Project", "shape": "string" },
{ "name": "fields.issuetype.subtask", "displayName": "Subtask", "shape": "boolean", "visible": false },
{ "name": "fields.creator.displayName", "displayName": "Creator", "shape": "string", "visible": false },
{ "name": "fields.reporter.displayName", "displayName": "Reporter", "shape": "string" },
{ "name": "fields.created", "displayName": "Created", "shape": "date" },
{ "name": "fields.updated", "displayName": "Updated", "shape": "date" },
{ "name": "fields.statuscategorychangedate", "displayName": "Last Status Category Change", "shape": "date", "visible": false },
{ "name": "fields.resolutiondate", "displayName": "Resolution Date", "shape": "date" },
{ "name": "url", "displayName": "Link", "shape": "url" },
{ "name": "blockState", "displayName": "Block State", "shape": "state", "visible": false },
{ "name": "blockLabel", "displayName": "Block Label", "shape": "string", "role": "label", "visible": false }
Parameters:
name
Mandatory
dataSourceConfig
Parameters
jql
Enter the JQL query you want to use here. The query will call the /rest/api/3/search
endpoint, please refer to the Atlassian Jira API documentation for details about which queries you can use: https://developer.atlassian.com/cloud/jira/platform/rest/v3/api-group-issue-search/#api-rest-api-3-search-get)
You can use mustache parameters in your query.
A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, {{timeframe.start}}
will insert the start time based on the timeframe configured within the tile, or {{name}}
will insert the name of the object(s) in scope.
You can use properties of objects and write them in between curly braces e.g {{name}}
to use them as mustache parameters. Whenever you use mustache parameters, you need to use a scope of objects that contain the property you're referencing.
For example, if objects of type "host" have a property called name
, you can use {{name}}
. This will resolve {{name}}
to the value of the name property of the different "host" objects used in the scope.
You can use the dashboard timeframe as a parameter in your query.
Tiles can be configured to:
The parameter for the dashboard timeframe is called timeframe
. You can modify the format (how the timeframe is sent via the query and how it will be displayed in SquaredUp) with properties like startTime
Example of how you'd insert the dashboard timeframe as a parameter in your query: {{timeframe.startTime}}
Meaning of the timeframe
properties
Note: You need to use a format that includes date and time if you want to use the dashboard timeframe settings "last hour" and "last 12 hours"
startTime | Date and time ( yyyy-MM-dd HH:mm) Uses the start date of the dashboard timeframe (now minus the dashboard timeframe) |
endTime | Date and time ( yyyy-MM-dd HH:mm) Uses the end date of the dashboard timeframe (now) |
startDate | Date only (yyyy-MM-dd) Uses the start date of the dashboard timeframe (now minus the dashboard timeframe) |
endDate | Date only (yyyy-MM-dd) Uses the end date of the dashboard timeframe (now) |
matches
Parameters
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
This custom Data Stream will enable you to get different granularity or metrics than the default Cost Data Stream for AWS.
Account Cost
Code example:
"name": "account-cost",
"groupBy": [
"Type": "DIMENSION",
"Key": "SERVICE"
"metrics": [
"AmortizedCost"
"granularity": "HOURLY",
"filter": {
"Dimensions": {
"Key": "SERVICE",
"Values": [
"AWS Cost Explorer"
"rowPath": [
"ResultsByTime",
"Groups"
"matches": {
"sourceType.0": {
"type": "equals",
"value": "AWS Account"
"metadata": [
"name": "ResultsByTime.TimePeriod.Start",
"displayName": "Date",
"shape": "date"
"name": "ResultsByTime.Groups.Keys.0",
"displayName": "Service",
"role": "label",
"shape": "string"
"name": "ResultsByTime.Groups.Metrics.AmortizedCost.Amount",
"displayName": "Cost",
"role": "value",
"shape": "currency"
"name": "ResultsByTime.Groups.Metrics.AmortizedCost.Unit",
"displayName": "Currency",
"shape": "string"
"name": "ResultsByTime.Estimated",
"displayName": "Estimated",
"shape": "boolean"
Parameters
name
Mandatory
dataSourceConfig
Parameters
Note: You'll find a detailed description about what each parameter does and which values you can use in the AWS API docs: https://docs.aws.amazon.com/aws-cost-management/latest/APIReference/API_GetCostAndUsage.html
metrics | Mandatory | The metrics you want to return, for example |
granularity | Mandatory | The granularity of the data, for example |
groupBy | Optional | Use this if you want to group the data. For example, the default AWS Cost Data Stream groups the data by If you don't group by anything, you'll get the costs for your whole account. |
filter | Optional | Use this if you want to filter AWS costs by different dimensions. For example, if you only want to return the costs of the Cost Explorer service, you can filter to that service here. If you don't use any filter, all cost data for your account will be returned. |
matches
Parameters
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
rowPath
Parameter
Optional
SquaredUp expects data in table form, and here's where you define how the table with your return data will be structured.
The rowPath will tell SquaredUp which items you want to convert into rows.
Example:
Let's say your return data looks like this:
"generalInfo": "some info",
"results": [
"name": "object 1",
"tags": [
"tag 1",
"tag 2",
"tag 3"
"name": "object 2",
"tags": [
"tag 1",
"tag 4"
Now it depends on what data you want to base your table on, do you want rows per object or per tag?
If you want to see which objects have which tags, your rowPath
would be results
, and your table would look like this:
name | tags | generalInfo |
object 1 | tag 1, tag 2, tag 3 | some info |
object 2 | tag 1, tag 4 | some info |
If you want to turn each tag into a row and see to which objects they are applied, your rowPath
would be results.tags
tags | name | generalInfo |
tag 1 | object 1 | some info |
tag 1 | object 2 | some info |
tag 2 | object 1 | some info |
tag 3 | object 1 | some info |
tag 4 | object 2 | some info |
As you can see in the example, each parameter gets turned into a column and the items of the parameter you chose as the rowPath
will be turned into rows.
You might also have noticed in the example that the parameter generalInfo
was included in both cases. This is because after going through all parameters on the same level as your rowPath
, SquaredUp will move through all levels above the rowPath
and create columns from those parameters, too. Parameters on levels below the rowPath
won't be included in the table.
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
Log Analytics Data Stream
Log Analytics Query
Code example:
"name": "customLogAnalyticsQuery",
"query": "Heartbeat | where TimeGenerated > ago(1d)",
"includeWorkspaceName": true
"rowPath": [],
"matches": {
"sourceType": {
"type": "equals",
"value": "microsoft.operationalinsights/workspaces"
"metadata": []
Parameters
name
Mandatory
dataSourceConfig
Parameters
query | Mandatory Insert your Kusto query here. The query must be written all in one line. Note: The Kusto query supports mustache parameters. Mustache parameters must refer to the property names of an Azure Application (e.g. A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, This data stream supplies scoped objects individually for mustache parameters. When there are multiple objects in scope this data source will send the query multiple times, once for each object. The results are then displayed together, for example in a single table. You can use properties of objects and write them in between curly braces e.g For example, if objects of type "host" have a property called |
includeWorkspaceName | Optional If you set this to |
matches
Parameters
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
Custom Metrics Data Stream
Metric
Code example:
"name": "customMetric",
"metricNames": "Network Out Total"
"rowPath": ["value", "timeseries", "data"],
"matches": {
"sourceType": {
"type": "oneOf",
"values": [
"microsoft.compute/cloudservices",
"microsoft.compute/cloudservices/roles",
"microsoft.compute/virtualmachines",
"microsoft.compute/virtualmachinescalesets",
"microsoft.compute/virtualmachinescalesets/virtualmachines"
"metadata": []
Parameters
name
Mandatory
dataSourceConfig
Parameters
metricNames | Mandatory Enter the metric you want to return. You can get a list of all available metrics in the Azure documentation: https://docs.microsoft.com/en-us/azure/azure-monitor/essentials/metrics-supported Make sure to use the correct metrics for the objects you're using. The Azure docs will tell you which metrics a re available for which objects. You should limit your Data Stream to those objects with the |
rowPath
Parameters
rowPath | The rowPath has to be ["value", "timeseries", "data"] |
matches
Parameters
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
Example for Custom Metrics
Metrics
Code example:
"name": "cpuUser",
"metric": "system.cpu.user"
"rowPath": [],
"matches": {
"type": {
"type": "equals",
"value": "datadog host"
"metadata": [
{ "name": "host", "displayName": "Host", "shape": "string" },
{ "name": "value", "displayName": "Value", "shape": "percent" },
{ "name": "timestamp", "displayName": "Timestamp", "shape": "date" }
Parameters
name
Mandatory
dataSourceConfig
Parameters
metric
Mandatory
To find out which metrics are available and their exact name, you can make an API GET request to the Datadog API. Please note that some of the metrics might not be compatible with the Datadog host object. Since this Data Stream is only for Datadog host objects, only metrics that are meant for host objects can be used.
Settings for the API request:
URL: https://API_URL
/api/v1/metrics?from=0
API_URL
depends on the URL of your Datadog instance and will be one of the following:
api.datadoghq.com
api.datadoghq.eu
api.ddog-gov.com
Headers:
DD-API-KEY: An API key you created in your Datadog instance
DD-APPLICATION-KEY: An application key you created in your Datadog instance
matches
Parameters
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
Datadog Data Streams only work with the object type host (datadog host
rowPath
Parameters
Can be left empty.
metadata
Parameters
To make sure that all your data has the proper shape you should enter the metadata
like shown in the example:
"metadata": [
{ "name": "value", "displayName": "Value", "shape": "percent/bytes/milliseconds/..." //depends on the metric// },
This ensures that the timestamp
comes back as a date
etc.
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
Note:
You can use mustache parameters in your data stream. You can use them in your query as well as anywhere else in the data stream code (for example, to call an API endpoint depending on an object's name).
Example 1: Using Query DSL syntax for your query
Query
Code example:
"name": "customQuery",
"queryBody": {
"query": {
"query_string": {
"query": "managedEntityDisplayName:\"Microsoft Windows Server 2016 Datacenter\""
"queryParams": {}
"rowPath": [
"hits",
"hits"
"matches": "all",
"metadata": [
"name": "hits.hits._index",
"displayName": "Index"
"name": "hits.hits._source.managedEntityDisplayName",
"displayName": "Entity Name"
"name": "hits.hits._source.counter",
"displayName": "Metric"
"name": "hits.hits._source.value",
"name": "hits.hits._source.timestamp",
"shape": "date"
Parameters:
| Mandatory | The internal name of the Data Stream. Can be used the refer to this Data Stream in a tile's JSON instead of using the Data Stream's internal ID. |
queryBody | Mandatory | Insert your Query DSL here. Your query needs to replace lines 5 to 9 in the code example above. |
rowPath | Mandatory | Depends on the data returned from your query. Enter the path to the row you want to use (the row path in the code example above is hits.hits). |
metadata | Mandatory | Depends on the data returned from your query. Use the code example above as a template for the columns you want to return. |
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
Example 2: Using Lucene syntax for your query
Query
Code example:
"name": "luceneQuery",
"queryBody": {},
"queryParams": {
"q": "managedEntityDisplayName:\"Microsoft Windows Server 2016 Datacenter\""
"rowPath": [
"hits",
"hits"
"matches": "all",
"metadata": [
"shape": "date"
Parameters:
q | Mandatory | Insert your Lucene query here (line 6 in the code example above). |
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
Example 3: Using any API endpoint with a custom call
Custom API Call
Code example:
"name": "customApiCall",
"method": "POST",
"endpoint": "{{name}}/_search",
"headers": {},
"params": {},
"body": {
"query": {
"query_string": {
"rowPath": [
"hits",
"hits"
"matches": "all",
"metadata": []
Parameters:
method | Mandatory | Enter the method (POST or GET) |
endpoint | Mandatory | Enter the API endpoint you want to call. |
headers , params | Optional | Here you can add headers and parameters to your API call. |
body | Mandatory or optional | Mandatory when you are using a POST |
metadata | Mandatory | Depends on the data returned from your query. |
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
Create generic scoped custom data stream for BigQuery
BigQuery (Scoped)
Code example:
"name": "exampleScopedBigQuery",
"query": "SELECT project.name, service.description FROM `<project_id>.<data_set_name>.<table_name>` WHERE project.id in ('{{sourceId}}') GROUP BY 1,2 ORDER BY 1,2;"
"rowPath": [],
"matches": {
"sourceType.0": {
"type": "oneOf",
"values": [
"GCP Project"
"metadata": [
{ "name": "name", "displayName": "Project","shape": "string", "role": "label" },
{ "name": "description", "displayName": "Service", "shape": "string" },
useTimeFrame | Optional You can add For example: Copy
![]() The dashboard timeframe is the current timeframe setting for a dashboard. Users can change the dashboard timeframe to see data for a different time span, for example, instead of showing data from "the last 12 hours" it can be changed to show data from "the last 7 days". Tiles can be configured to:
Tip: Indicate with the name of a tile if the tile's timeframe can be changed. For example, naming a tile "Performance during the last week" tells users that this tile always shows data for the last week. Naming a tile just "Performance" indicates to users that changing the dashboard timeframe will change the data. | |||||||||||||||||||||||||
query | Mandatory Insert your query here. The query must be written all in one line. The query supports mustache parameters (in between curly braces e.g {{name}}). Mustache must refer to the property names of a GCP object that is the scope of the query. In the example we scope a query by GCP project. The query will execute for each object in the scope and return all results. ![]() A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, This data stream supplies scoped objects individually for mustache parameters. When there are multiple objects in scope this data source will send the query multiple times, once for each object. The results are then displayed together, for example in a single table. You can use properties of objects and write them in between curly braces e.g For example, if objects of type "host" have a property called | |||||||||||||||||||||||||
rowPath | Optional Depends on the data returned from your query. Enter the path to the row you want to use. | |||||||||||||||||||||||||
matches | Matches should be populated appropriately to the type of objects in the scope, that you want this data stream to work for. Note: Defining the With the Format for Copy
Example 1: Using a Prometheus query
Prometheus Query (Global)
Code example:
"name": "prometheus_global",
"matches": "none",
"ignoreTimeFrame": true,
"query": "sum by (instance) (rate(kubedns_probe_dnsmasq_latency_ms_sum[1m])) / sum by (instance) (rate(kubedns_probe_dnsmasq_latency_ms_count[1m]))"
"rowPath": [
"results"
"metadata": []
name
Mandatory
dataSourceConfig
Parameters
query | Mandatory Note: You can't use mustache parameters in the query since it doesn't use the |
ignoreTimeFrame | Optional You can add the ![]() The dashboard timeframe is the current timeframe setting for a dashboard. Users can change the dashboard timeframe to see data for a different time span, for example, instead of showing data from "the last 12 hours" it can be changed to show data from "the last 7 days". Tiles can be configured to:
matches
Parameters
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
rowPath
Parameters
Mandatory
Depends on the data returned from your query. Enter the path to the row you want to use (the row path in the code example above is results).
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
Example 2: Get CPU usage for a selected object from a GCP cluster
Note: This Data Stream requires a Google Cloud Platform data source which has to be configured to return information from a cluster.
PromQL
Code example:
"name": "prometheuscpu",
"matches": {
"sourceType": {
"type": "equals",
"value": "compute#instance"
"query": "instance:node_cpu:rate:sum{instance=\"{{name}}\"}"
"rowPath": [
"results"
"metadata": [
name
Mandatory
dataSourceConfig
Parameters
query | Mandatory You can use mustache parameters in the query. ![]() A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, This data stream supplies scoped objects individually for mustache parameters. When there are multiple objects in scope this data source will send the query multiple times, once for each object. The results are then displayed together, for example in a single table. You can use properties of objects and write them in between curly braces e.g For example, if objects of type "host" have a property called |
ignoreTimeFrame | You can add the ![]() The dashboard timeframe is the current timeframe setting for a dashboard. Users can change the dashboard timeframe to see data for a different time span, for example, instead of showing data from "the last 12 hours" it can be changed to show data from "the last 7 days". Tiles can be configured to:
matches
Parameters
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
rowPath
Parameters
Mandatory
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
SWQL
Code example:
Information about parameters in the script:
"name": "my-custom-swql-datastream",
"swql": "SELECT something FROM somewhere WHERE something like something"
"rowPath": ["results"],
"matches": {
"sourceType": {
"type": "equals",
"value": "SolarWinds Host"
"metadata": []
Parameters
name
Mandatory
dataSourceConfig
Parameters
swql | Here you define which data to return, written in the format |
matches
Parameters
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
Example 1: Get Windows Event Log Entries for Given Hosts
Note: This Data Stream uses Host objects which need to come from a different data source (for example, from the VMware vCenter data source), and performs a query to get Windows application log event messages.
Splunk Enterprise Query (Scoped)
Code example:
"name": "SplunkAppEventsForHost",
"query": "search source=\"WinEventLog:Application\" | where host = \"{{name}}\" | fields host,Message"
"matches": {
"type": {
"type": "equals",
"value": "host"
"rowPath": [],
"metadata": [
{ "name": "_indextime", "displayName": "Timestamp", "shape": "date", "role": "timestamp" },
{ "name": "Message", "displayName": "Message", "shape": "string", "role": "value" }
name
Mandatory
dataSourceConfig
Parameters
matches
Parameters
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
Example 2: Get Results for Saved Report
Note: This Data Stream uses the Splunk Enterprise organization object and doesn't rely on objects coming from other data sources.
Code example:
"name": "SplunkRunMySavedReport",
"query": "| savedsearch mySavedReport | fields host,Message"
"matches": {
"sourceType": { "type": "equals", "value": "Splunk Enterprise Organization" }
"rowPath": [],
"metadata": [
name
Mandatory
dataSourceConfig
Parameters
matches
Parameters
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
Example 3: Get Time-Series Data for Metric
Code example:
"name": "SplunkMpoolUsedMetric",
"query": "| mstats avg(\"spl.mlog.mpool.used\") WHERE \"index\"=\"_metrics\" span=60s chart=true"
"matches": {
"rowPath": [],
"metadata": [
{ "name": "_time", "displayName": "Timestamp", "shape": "date", "role": "timestamp" },
{ "name": "avg(spl.mlog.mpool.used)", "displayName": "Value", "shape": "number", "role": "value" }
name
Mandatory
dataSourceConfig
Parameters
matches
Parameters
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
metadata
Parameter
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
Example of a scoped HTTP Request data stream
Creating a custom data stream allows you to created a scoped data stream, i.e. a data stream that makes use of objects in the scope.
HTTP Request (scoped)
Code example:
"name": "scope example",
"matches": "all",
"endpointPath": "post",
"httpMethod": "post",
"idSeparator": "], [",
"headers": [
"key": "header1",
"value": "header1Val"
"key": "sourceIds",
"value": "[{{sourceIds}}]"
"expandInnerObjects": true
"rowPath": []
You should set the matches
statement so that your custom data stream appears when you select the appropriate object types in the tile editor. You can use additional mustache constructs when using the scoped entry point: targetNodes
, sourceId
, sourceIds
in selected dataSourceConfig
parameters as shown below. The separator inserted between sourceId
values in the sourceIds
replacement string can be changed by setting idSeparator
in dataSourceConfig
Parameters
name
parameterMandatory
dataSourceConfig
parametersendpointPath | Mandatory | (string) - the endpoint path relative to the data source config's base URL to be queried (supports mustache parameters) |
httpMethod | Mandatory | (string) - "get" or "post" |
headers | Optional | (array of key, value pairs) - any additional headers for this request (supports mustache parameters in |
getArgs | Optional | (array of key, value pairs) - any additional query args (supports mustache parameters in |
postBody | Optional | (string) – only if httpMethod is "post", a JSON string defining the body (supports mustache parameters) |
idSeparator | Optional | (string) - this controls how the replacement value "sourceIds" is generated |
pathToData | Optional | (string) - where in the returned payload, the desired data is to be found |
expandInnerObjects | Optional | (boolean) - whether to expand inner objects and arrays in the desired data |
matches
parametersNote: Defining the matches
With the matches
Format for matches
"matches": {
"ObjectProperty": {
"type": "equals",
"matches": {
"ObjectProperty": {
"type": "oneOf",
a
SourceName
type
"matches": {
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
rowPath
parameterOptional
The rowpath
(Path to data) will tell SquaredUp which items you want to convert into rows.
Example:
"results": [
"name": "object 1",
"tags": [
"tag 1",
"tag 2",
"tag 3"
"name": "object 2",
"tags": [
"tag 1",
"tag 4"
If you want to see which objects have which tags, your rowpath
would be results
name | tags |
If you want to turn each tag into a row and see to which objects they are applied, your rowpath
tags | name |
tag 1 | object 1 |
tag 1 | object 2 |
tag 2 | object 1 |
tag 3 | object 1 |
tag 4 | object 2 |
As you can see in the example, each parameter gets turned into a column and the items of the parameter you chose as the rowpath
metadata
parameterOptional, but recommended
The metadata
parameters:
metadata
value
Parameters:
parameter.
Basic types, like:
boolean
,date
,number
,string
currency
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
customUnit
url
Tip:
