AppDynamics plugin
Monitor key metrics from your AppDynamics environment.
How to add an AppDynamics data source
Before you add the data source:
Log into your AppDynamics account.
Create a new API client see AppDynamics: Creating API Clients
Make a note of the API client name and client secret.
Now use the API client to configure the data source in SquaredUp:
Display Name:
Account Name:
Enter the name of your AppDynamics account.
Note: You usually log in to your AppDynamics account with an account name and a user name. You need to use the account name, not the user name.
API Client Name:
Enter the name of the API client you created.
API Client Secret:
Enter the API client secret you created.
Install Sample Dashboards:
Data source access levels
Access Level:
Click Add.
Using the AppDynamics data streams
Metric
This data stream calls the /controller/rest/applications/.../metric-data
endpoint with a mostly pre-set metric path, and allows you to enter a custom metric name.
In the tile editor, filter by the AppDynamics data source, select Metric from the data stream list and then click Next.
Select the AppDynamics objects that you want to use and then click Next.
Enter a Metric, for example:
CPU|%Busy
The majority of the metric path is pre-set based on the scoped item’s type. These pre-set paths are as follows, where
{{metric}}
is the metric provided in the configurable data stream:Object Type
Metric Path
app
Overall Application Performance|{{metric}}
appdynamics tier
Overall Application Performance|{{name}}|{{metric}}
appdynamics node
Overall Application Performance|{{tierName}}|Individual Nodes|{{name}}|{{metric}}
host
Application Infrastructure Performance|{{tierName}}|Individual Nodes|{{name}}|Hardware Resources|{{metric}}
db
Databases|{{name}}|{{metric}}
appdynamics eum app
End User Experience|{{metric}}
Click Save.
