Providers (deprecated)
This feature is deprecated. Use the new and more powerful Web API plugin. You only need to use the steps below if you added a provider before the Web API data source was available.
This allows you to query data from third-party APIs and present that data on a dashboard. If you haven't already added a provider we recommend that you use the new Web API data source instead, see Web API plugin
Browse to Settings > Web API > Providers and click Add new provider.
Enter a name for the provider, for example
Star Wars
Enter the base URL of the API to be used for requests, for example
https://swapi.dev/api
Method: Post or Get.
For example, Get for the Star Wars API.
Authentication: None or Basic
For example, None for the Star Wars API.
Headers can be added if required.
No header information needed for the Star Wars API.
Query Parameters can be added if required.
None are needed for the Star Wars API.
Click Save.
Add a new data tile and in the configuration scope the tile to SquaredUp
Choose the + Web API data stream.
Enter a name for this data stream. For example, Star Wars People
Select a provider from the list. For example, Star Wars.
Path Suffix: Choose the API method you want to call. For example, for the Star Wars API you can type
people
to use the People method.Row Path: Enter the response path of the property you want to turn into rows. For example, for the Star Wars API type
results
.Click Save.
Optionally, you can configure filtering, grouping, sorting etc as normal.
Configure Data Stream
Filtering
Data can be filtered according to whether data in a column meets or does not meet specified text or numerical value conditions. Depending on the data you are filtering, available options include: Equals, Not equals, Contains, Doesn't contain, Less than, Greater than, Before now, After now, Is empty, Is not empty.
Dates can be filtered by Before now or After now (e.g. to show overdue orders). Text matching is case sensitive.
You are able to add multiple filter conditions. Available options are:
AND – all conditions must be satisfied (e.g.
Status-Equals-Closed
ANDType-Equals-Question
).OR – any condition can be satisfied (e.g.
Status-Equals-Pending
ORStatus-Equals-Closed
Grouping
For example, for AWS cost data you might Group by
label
, choose Aggregation typeTotal
with Aggregation columnAmount
, to show a table or bar chart of cost per label.Which columns are available depends on the data stream you chose.
Bucket by
If you group by a time column, and further grouping is possible, then the Bucket by dropdown will appear, which allows you to control how the time data is grouped, for example by
hour
,day
,month
etc.Aggregation type and column
Using this dropdown you can choose how to summarize your data, for example as a
count
,average
ortotal
.For example, for a Bar Chart of ticket data you might Group by
Date created
, choose Bucket byDay
with Aggregation typeCount
, to show a line graph of tickets per day. Or for a Bar Chart of Azure Resource Group cost you might Group byTimestamp
, Bucket byDay
, Aggregation typeTotal
and Aggregate columnCost
.Sorting
- You can also add Monitors or KPIs, as you would for any tile.
