Atlassian Jira Service Management plugin
This plugin allows you to add a data source to monitor service desks from your Atlassian Jira Service Management environment.
Only the Jira Cloud offering is supported by this data source.
How to add a Atlassian Jira Service Management data source
Display Name:
Domain URL:
The domain for your Atlassian instance in the format
https://your-domain.atlassian.net
User Email Address:
Enter the email address of your Atlassian user account. You need to have access to that user account since you need to create an API token with the same user you entered here (see next step).
Here's how the email address (Atlassian user account) you use here influences which data will be returned:
For Confluence data source: If the user account doesn't have access to a space, the space won't be returned. If the user account has read-only access to a space, you'll get the pages in that space.
For the Jira data source: Even if the user account you use here has just read-only access to a project, the issues in that project will still be returned.
For the Jira Service Management data source: If the user account doesn't have access to any Jira Service Management service desks, nothing will be returned by the data source.
API Token:
Go to your Atlassian account, create an API token, and paste it in here. You can go directly to your Atlassian API tokens using this link: https://id.atlassian.com/manage-profile/security/api-tokens
Note: You need to create the API token with the same user account you used for the User Email Address field.
Tip: If you are using the Atlassian Confluence and the Atlassian Jira data source you can use the same token for both data sources.
Data source access levels
Access Level:
Click Add.
Using the Atlassian Jira Service Management data streams
Service Desks
Scope to the Atlassian Jira Service Management data source. A number of object types are discovered:
Customers
Organizations
Queues
Request Types
Service Desks
Once you have selected the object, a list of several data streams will be provided. For example, you can select Queues as the object type, and then select the Queue Requests data stream to bring up a table of your tickets.
Queue data streams are defined around a JQL query, timeframes within SquaredUp will not be used on Queue data steams as these provide inherent filtering.
Timeframes can be used for other object types. Some of the available data streams can be used in conjunction with the dashboard/tile timeframe to filter by date. For example, Request Type data streams could be used in the following ways:
Requests / Closed (resolution date) – use with a 30 days timeframe to show all closed requests with a resolution date from the last 30 days.
Requests / Open (created date) – use with a 7 days timeframe to show all open requests that were created within the last 30 days.
AQL Query
In the tile editor, filter by the Atlassian Jira Service Management data source, select AQL Query from the data stream list and then click Next.
Query:
Enter the AQL query that you want to use, for example:
objectType = "Computers"
.See Jira Service Management: AQL for more information about AQL queries.
Only the first 300 objects will be returned.
Click Save.
Insight Objects by Type
In the tile editor, filter by the Atlassian Jira Service Management data source, select Insight Objects by Type from the data stream list and then click Next.
Object Type:
Select the Object Type that you want to use from the dropdown, for example:
Clients
.Only the first 300 objects will be returned.
Click Save.
