CircleCI plugin
Monitor the Pipelines and Workflows from your CircleCI environment.
How to add the CircleCI plugin
Create a personal API token in CircleCI
Add the CircleCI plugin to SquaredUp
Paste in the Personal API Token you created.
Plugin access levels
Access Level:
Click Save.
