UptimeRobot plugin
Monitor the availability and performance of your services from your UptimeRobot environment.
How to add the UptimeRobot plugin
Display Name:
API Token:
Log into your UptimeRobot instance, copy the Read-Only API Key, and paste it in here.
Plugin access levels
Access Level:
Click Save.
