Merging objects
Automatic merge
If different plugins import the same object, the different objects get automatically merged into one object in SquaredUp. For example a server that runs as server in Azure, is monitored by Pingdom, and is part of an app in NewRelic gets imported from each of those plugins, but ends up being just one object in SquaredUp, with all the properties it gets from all the different plugins.
Manual merge
You can merge objects yourself by using custom correlations. To merge objects from different plugins, their type and at least one other property must be identical. While links between two objects can be created just based on the value of a property, for merging objects the name of the property and its value must be identical.
After selecting the same type and property, enter "is" as the Association Label. The "is" label tells SquaredUp not to create a link between those objects but instead to merge them into one object if the values of the property match.
Example:
Let's say you imported person objects from two different plugins. Both plugins use the type person and both types have a property called name. Instead of seeing two separate objects for the same person, you can merge them by creating this correlation (as long as the name is spelled exactly the same in the name property):
Type: person
Property: name
To:
Type: person
Property: name
Association label: is
