Atlassian Jira plugin
Monitor the Projects, Releases and Issues from your Jira Software environment.
How to add the Atlassian Jira plugin
Display Name:
Domain URL:
The domain for your Atlassian instance in the format
https://your-domain.atlassian.net
User Email Address:
Enter the email address of your Atlassian user account. You need to have access to that user account since you need to create an API token with the same user you entered here (see next step).
Here's how the email address (Atlassian user account) you use here influences which data will be returned:
For Confluence plugin: If the user account doesn't have access to a space, the space won't be returned. If the user account has read-only access to a space, you'll get the pages in that space.
For the Jira plugin: Even if the user account you use here has just read-only access to a project, the issues in that project will still be returned.
API Token:
Go to your Atlassian account, create an API token, and paste it in here. You can go directly to your Atlassian API tokens using this link: https://id.atlassian.com/manage-profile/security/api-tokens
Note: You need to create the API token with the same user account you used for the User Email Address field.
Tip: If you are using the Atlassian Confluence and the Atlassian Jira plugin you can use the same token for both plugins.
Plugin access levels
Access Level:
Click Save.
Using the Jira plugin
Data Streams
There are two types of data streams available for this plugin
Data streams installed with the plugin
Configurable data streams see Using Configurable data streams with the Jira plugin
Issues
This data stream calls the /rest/api/3/search
endpoint, and allows you to enter a custom JQL query.
Scope to a Jira item that supports issues
Select + Issues from the data stream list
Enter a JQL Query, for example:
project={{key}}&updatedDate>='{{timeframe.startTime}}'
A mustache parameter is a dynamic value, the actual value will be inserted from the properties of the object(s) in scope.
This data stream supplies scoped objects individually for mustache parameters. When there are multiple objects in scope this plugin will send the query multiple times, once for each object. The results are then displayed together, for example in a single table.
You can use properties of objects and write them in between curly braces e.g {{name}}
to use them as mustache parameters. Whenever you use mustache parameters, you need to use a scope of objects that contain the property you're referencing.
For example, if objects of type "host" have a property called name
, you can use {{name}}
. This will resolve {{name}}
to the value of the name property of the different "host" objects used in the scope.
An additional timeframe
object is also available for mustache syntax
Available properties of the additional timeframe
object are as follows:
Property | Description | Example |
start | The start time of the timeframe in ISO format | 2022-05-10T16:00:00.000Z |
end | The end time of the timeframe in ISO format | 2022-05-11T16:00:00.000Z |
unixStart | The start time of the timeframe in Unix format (seconds) | 1652198400 |
unixEnd | The end time of the timeframe in Unix format (seconds) | 1652284800 |
interval | A fraction of the length of the timeframe in ISO interval format | PT15M |
startDate | The start time of the timeframe in yyyy-MM-dd format | 2022-05-10 |
endDate | The end time of the timeframe in yyyy-MM-dd format | 2022-05-11 |
startTime | The start time of the timeframe in yyyy-MM-dd HH:mm format | 2022-05-10 16:00 |
endTime | The end time of the timeframe in yyyy-MM-dd HH:mm format | 2022-05-11 16:00 |
