Prometheus plugin
The data source lets you monitor any metrics from your Prometheus environment using custom PromQL queries.The data source is available as a Cloud data source and also as an on-premises data source.
Note: This data source is of great use in addition to other data sources. It enables you to get different kinds of data and insights about objects that have been indexed by other data sources.
How to add a Prometheus data source
You will only need to configure and deploy an agent if you adding the Prometheus on-premises data source. If you want to add the Prometheus Cloud data source, you only need to follow the steps detailed in Add a Prometheus data source to SquaredUp.
Configure and deploy an agent
Prerequisites for Agents
The Agent needs to run on a Windows machine that has access to the entry point for the on-premises data source
Make sure the Agent is able to make outbound connections on port 443 (no inbound required) to SquaredUp, *.amazonaws.com and Microsoft APIs (Azure Relay).
Parameters to replace:
-ApiKey "key"
Mandatory Replace key
Optional To run the Agent as a domain service account (for example, for the SCOM data source), provide the username as domain\username
where
key
Where
<ServiceName>
Start-Service -Name squpagent
or
Where
<DisplayName>
In SquaredUp browse to Data Sources > Add data source and search for the data source. Alternatively, browse to Settings > Data Sources > Add data source.
Enter the URL of your Prometheus instance.
Enter the API Token if it is required to access your server.
Select the Agent Group from the list.
This is only required if you are configuring the Prometheus on-premises data source.
By default, Restrict access to this data source? is set to off. The data source can be viewed, edited and administered by anyone. If you would like to control who has access to this data source, switch Restrict access to this data source? to on.
Use the Restrict access to this data source? dropdown to control who has access to the workspace:
If the user is not available from the dropdown, you are able to invite them to the data source by typing in their email address and then clicking Add. The new user will then receive an email inviting them to create an account on SquaredUp. Once the account has been created, they will gain access to the tenant.
Data source access levels
Access Level:
Click Save.
Using the Prometheus data streams
Creating a data stream using the configurable data stream (simplest option) see Creating a data stream using the configurable data stream
Write a custom data stream (advanced use) see Writing a custom data stream (advanced users)
PromQL
This data stream calls the /api/v1/query
endpoint, and allows you to enter a custom query.
In the tile editor, filter by the Prometheus data source, select the PromQL data stream and then click Next.
You can either select the scoped PromQL data stream or the global PromQL data stream.
If you selected the scoped Prom QL data stream, select the objects you want to use and then click Next.
You do not need to do this if you have selected the global PromQL data stream.
Enter a Query, for example:
sum by (instance) (rate(kubedns_probe_dnsmasq_latency_ms_sum[1m])) / sum by (instance) (rate(kubedns_probe_dnsmasq_latency_ms_count[1m]))
Mustache parameters are supported when scoped to an object.
Supports mustache parameters
A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example,
{{timeframe.start}}
will insert the start time, or{{name}}
will insert the name of the object(s) in scope.This data stream supplies scoped objects individually for mustache parameters. When there are multiple objects in scope this data source will send the query multiple times, once for each object. The results are then displayed together, for example in a single table.
You can use properties of objects and write them in between curly braces e.g
{{name}}
to use them as mustache parameters. Whenever you use mustache parameters, you need to use a scope of objects that contain the property you're referencing.For example, if objects of type "host" have a property called
name
, you can use{{name}}
. This will resolve{{name}}
to the value of the name property of the different "host" objects used in the scope.Ignore Timeframe:
Tick this checkbox if you wish to return a single scalar value rather than a table of results.
Click Save.
Go to Settings > Data Streams.
Click Add new Data Stream.
Choose the Data Source this Data Stream is for.
After you've chosen the data source a new field Entry Point appears.
Entry point and code:
What is an entry point?
Each data stream uses an entry point, which can either be global (unscoped) or scoped, and this determines whether the data stream uses the tile scope.
To find out which entry point to select and get code examples for the Code field, see the help below.
Example 1: Using a Prometheus query
Which data stream do I have to select?
Prometheus Query (Unscoped)
Display Name
Mandatory
The internal name of the data stream. Can be used the refer to this data stream in a tile's JSON instead of using the data stream's internal ID.
dataSourceConfig
Parameters
Query | Mandatory
Note: You can't use mustache parameters in the query since it doesn't use the |
Ignore Timeframe | Optional You can add the ![]() The dashboard timeframe is the current timeframe setting for a dashboard. Users can change the dashboard timeframe to see data for a different time span, for example, instead of showing data from "the last 12 hours" it can be changed to show data from "the last 7 days". Tiles can be configured to:
Tip: Indicate with the name of a tile if the tile's timeframe can be changed. For example, naming a tile "Performance during the last week" tells users that this tile always shows data for the last week. Naming a tile just "Performance" indicates to users that changing the dashboard timeframe will change the data. |
Example 2: Get CPU usage for a selected object from a GCP cluster
Note: This Data Stream requires a Google Cloud Platform data source which has to be configured to return information from a cluster.
Prometheus Query (Scoped)
Display Name
Mandatory
dataSourceConfig
Parameters
Query | Mandatory You can use mustache parameters in the query.
![]() A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, This data stream supplies scoped objects individually for mustache parameters. When there are multiple objects in scope this data source will send the query multiple times, once for each object. The results are then displayed together, for example in a single table. You can use properties of objects and write them in between curly braces e.g For example, if objects of type "host" have a property called |
Ignore Timeframe | You can add the ![]() The dashboard timeframe is the current timeframe setting for a dashboard. Users can change the dashboard timeframe to see data for a different time span, for example, instead of showing data from "the last 12 hours" it can be changed to show data from "the last 7 days". Tiles can be configured to:
