ServiceNow plugin
Monitor the Incidents and Change Requests from your ServiceNow environment.
How to add the ServiceNow plugin
Prerequisites for the ServiceNow account
How the ServiceNow account affects the tile
The permissions of the ServiceNow account you are using for your ServiceNow plugin affect what you can see and do in the tile.
We recommend using a service account, which means you create an account specifically to use with the ServiceNow plugin. You have different options for setting up this service account:
ServiceNow admin account
Give the ServiceNow account the admin role. This will give you full functionality in the tile.
ServiceNow non-admin account with ACLs
If you don't want to use the admin role due to security concerns, give the ServiceNow account only the rest_api_explorer role and use ACLs to give the account more rights. Using accounts without admin permissions may cause data streams to error.
How to add the necessary ACLs to your ServiceNow account
When you are using a non-admin ServiceNow account for a plugin, the functionality of the ServiceNow plugin is limited.
Adding them directly to a user account, meaning you are adding the ACLs to the service account you are using for the ServiceNow plugin.
Adding them to a role. We recommend that you create a new role specifically just for adding the ACLs to it. Then you need to assign the role to the service account you are using for the ServiceNow plugin.
A benefit of adding the ACLs to a role is that it makes them easier to manage and you can assign the role to different users (in this case, service accounts) if you want to use different service accounts for different ServiceNow plugins.
sys_filter
sys_dictionary.*
sys_dictionary
sys_db_object
sys_ui_list
sys_db_object.*
sys_ui_list.*
If you don't want to create ACLs and use only roles, give the ServiceNow account the roles rest_api_explorer and web_service_admin. Using accounts without admin permissions may cause data streams to error.
Add the ServiceNow plugin to SquaredUp
Enter the URL of your ServiceNow instance.
Enter the username and password for the API. See Prerequisites for the ServiceNow account
Adding Custom Classes is optional, and can be left empty. If you would like SquaredUp to import your custom classes you can list any number of classes here using their table names. By default, the plugin imports the Business Application class (table name: cmdb_ci_business_app) and the Service class (table name: cmdb_ci_service).
Plugin access levels
Access Level:
Click Save.
