Zendesk plugin
Monitor the tickets from your Zendesk Support environment.
How to add the Zendesk plugin
Enter your Zendesk Organization name. You can see this in your Zendesk URL <organization>.zendesk.com. Don't enter the .zendesk.com part, just the organization name.
Enter a Zendesk username to access the API
for examplejdoe@example.com
Create an API token in Zendesk and paste it in.
Generate an API token from Zendesk Admin Center > Apps and integrations > APIs > Zendesk API
Plugin access levels
Access Level:
Click Save.
