AWS plugin
Monitor your AWS environment, including EC2, Lambda Functions, CloudWatch and more.
How to add the AWS plugin
You will need
The Access key ID and Secret access key of an IAM user with programmatic access.
The AWS Account ID and Target Regions for your AWS resources.
User with Programmatic access
You will need to configure a new or existing user with read-only programmatic access.
See AWS credentials - Programmatic access and Creating an IAM user in your AWS account
Add the AWS plugin to SquaredUp
Enter the Access Key ID and Secret Access Key of the IAM user with programmatic access.
Input the Target Regions for your AWS resources, i.e. us-east-2, eu-west-1
Enter the AWS Account ID
Enter an Account name to help you remember which account and credentials you have used above. For example, you might type prod to remind you that you used the production account details.
Plugin access levels
Access Level:
Click Test and save to validate the plugin configuration.
Testing outcomes
Testing passed with warnings – warnings will be listed and potential fixes suggested. You can still use the plugin with warnings. Select Save with warnings if you believe that you can still use the plugin as required with the warnings listed. Alternatively, address the issues listed and then select Rerun tests to validate the plugin configuration again. If the validation now passes, click Save.
Testing Failed – errors will be listed and potential fixes suggested. You cannot use the plugin with errors. You are able to select Save with errors if you believe that a system outside of SquaredUp Cloud is causing the error that you need to fix. Alternatively, address the issues listed and then select Rerun tests to validate the plugin configuration again. If the validation now passes, click Save.
You can edit any plugin configurations at any time from Settings > Plugins.
The import time will depend on the size of your AWS environment.
Using the AWS plugin
Data Streams
There are three types of data streams available for this plugin
Data streams installed with the plugin, see Tips for using the AWS Data Streams
Configurable data streams see Using Configurable data streams with the AWS plugin
Custom data streams, see How to add a custom Data Stream for AWS
The AWS plugin comes with many configurable data streams which appear when scoped to anything in AWS:
CloudWatch Logs, see CloudWatch Logs
CloudWatch Metrics Query, see CloudWatch Metrics Query
Cost, see Cost
CloudWatch Metrics, which show dependent on the scope specified, see CloudWatch Metric
CloudWatch Logs
This data stream allows you to fetch logs from any log group and run queries on them. Simply select the AWS plugin in the tile editor and this data stream will appear.
Display Name: Enter a Display Name for the new data stream.
Region: Select the AWS region to target.
Log group(s): Enter the names of the log groups you want to query/fetch logs from, separated by commas.
Limit: Enter a limit for the number of results you want to fetch per query.
Query: Enter the Log Insights query you want to run. Use Log Insights in CloudWatch logs in the AWS console to write your queries. For example, you can add a filter to they query | filter: @message like 'error'
. See AWS: CloudWatch Logs Insights query syntax
Allows you to query any metric in AWS CloudWatch using the source from the CloudWatch Metrics explorer. Simply select the AWS plugin in the tile editor and this data stream will appear.
Query: In CloudWatch Metrics you can either copy the JSON from the Source tab or the SQL Query from the Query Editor.
Cost
Explore costs occurred in AWS. Simply select the AWS plugin in the tile editor and then select the +Cost data stream.
Filters and grouping info at AWS: GetCostAndUsage
Metric: Select the cost metric from Cost Explorer e.g. UnblendedCost.
Granularity: Select how frequently you want to sample the data: Hourly, Daily, or Monthly.
Group By: Add grouping for the cost request by Dimension, Tag or Cost.
Filter: Enter the filter used to remove cost data from the query based on dimensions.
Cost examples:
Group by availability zone
"Type": "DIMENSION",
"Key": "AZ"
Group by service
"Key": "SERVICE"
Filter to lambda cost only
"Dimensions": {
"Key": "SERVICE",
"Values": [
"AWS Lambda"
Filter to remove tax and developer support
"Not": {
"Dimensions": {
"Key": "SERVICE",
"Values": [
"Tax",
"AWS Support (Developer)"
CloudWatch Metric
The +CloudWatch Metric configurable data stream will appear when you scope to particular objects.
The current resources supported are:
API Gateway
CloudFront
CloudWatch RUM
CloudWatch Synthetics
Cognito UserPools
DynamoDB
ECS clusters
EC2
ElastiCache Memcached
ElastiCache Redis
Elastic load balancers (ELB)
Lambda
Route53
RDS
S3 buckets
WAF WebACLs
Metric: Select the metric that you want to measure.
Statistic: Select the required statistic.
Available statistics vary depending on the metric that has been selected.
The following resources have their own configurable data streams as they have additional fields:
+DynamoDB Metric: optional operation type that is required to fetch certain metrics.
+S3 Metric: requires you to select a storage type depending on metric.
This plugin comes with several data streams that you can use in the tiles on your dashboards. Here you'll find tips and ideas for using these data streams to display the data you're interested in.
Using the Cost Data Stream
This Data Stream uses the AWS Cost Explorer to show you data about how much each of you AWS services cost you.
The Cost Data Stream returns the daily unblendedcosts per service. If you want to use a different granularity (like monthly costs) or a different cost metric (like amortized costs), you need to create a custom Data Stream (see Custom Data Streams). Costs will always be returned in the currency you set in your AWS account.
Note: You need the AWS Cost Explorer service to use the Cost Data Stream. This service collects the costs of your other services. Please be aware that AWS charges you for every request that the AWS Cost Explorer sends. Each tile that uses the AWS Cost Data Stream makes a request every time the dashboard reloads.
General tips for using the Cost Data Stream
Tax costs
Tax is a cost that will be added to your other costs monthly on one specific day. A good way to visualize tax costs is the Line Graph, where you'll see a spike on tax day when the dashboard timeframe is set to 30 days.Line Graphs
Remember that the cost data from AWS is daily data. Therefore, Line Graphs will only show data when the dashboard timeframe is set to 7 days or 30 days. Any smaller timeframe will leave the Line Graph empty since there's not enough data.
Tiles can be configured to:
Scalars
A Scalar displays one value. A Scalar is useful to show a specific number like "total cost of my services" or "free disk space on this server".When a Data Stream returns multiple values (meaning a table with multiple rows), you will still be able to pick the Scalar visualization, but the Scalar will only show the value of the first row.
Use cases: Questions you can answer with the Cost Data Stream
Create a new tile on a dashboard with the following settings:
Scope:
Select a scope that contains your AWS account(s). If you haven't created a scope that contains your AWS account(s), you can create one by clicking on the + next to Scope.
Data Stream:
Select the Cost Data Stream.
Visualization:
You could select a Table or a Line Graph to visualize your data. A Line Graph is probably the more convenient way to see what each service cost you over time.
Scope:
Data Stream:
Click on the Configure button next to the Cost Data Stream to open the advanced settings. The following settings will get you the result of how much all services combined cost you in total or on average:
Group by | Date (For each day...) |
Aggregate column | Cost (...show me the combined costs...) |
Aggregation type | Average or total (... on average or in total.) |
Visualization:
You could select a Table or a Line Graph to visualize your data. A Line Graph is probably the more convenient way to see what all services combined cost you over time.
Scope:
Data Stream:
Click on the Configure button next to the Cost Data Stream to open the advanced settings. The following settings will get you the result of how much each service cost you:
Group by | Service (For each service...) |
Aggregate column | Cost (...show me all costs combined for this service within my chosen timeframe...) Note: Instead of choosing a fixed timeframe here, you can choose the timeframe dynamically via the dashboard timeframe when you're looking at your finished tile. |
Visualization:
There are different ways to visualize your data, try a Donut or a Table.
After you're done creating the tile, you can specify the timeframe by changing the dashboard timeframe to today, 7 days or 30 days.
Scope:
Data Stream:
Group by | None (For all of my services...) |
Aggregate column | Cost (...show me all costs combined for all services within my chosen timeframe...) Note: Instead of choosing a fixed timeframe here, you can choose the timeframe dynamically via the dashboard timeframe when you're looking at your finished tile. |
Visualization:
Since you only want to see one number (all costs for all services), you can choose a Scalar.
Using the Cost Anomalies Data Stream
This Data Stream shows you the Cost Anomaly alerts from AWS. It returns the alerts you have set up manually as well as the AI generated ones (when AWS suspects you're paying too much for a service).
Which visualization should I use?
This Data Stream returns a list of alerts and a Table is the best way to display them. The Table will show you:
The Date the alert was triggered
The Service for which the alert was triggered
The Anomaly Score, a AWS internal rating system which defines how severe the anomaly is
The Total Impact, meaning how much more than expected you payed
The Name of the monitor that triggered the alert
Go to Settings > Data Streams.
Click Add new Data Stream.
Choose the plugin this Data Stream is for.
After you've chosen the plugin a new field Data Source appears.
Data source and code:
To find out which data source to select and get code examples for the Code field, see the help below.
Example for a custom AWS Cost Data Stream
This custom Data Stream will enable you to get different granularity or metrics than the default Cost Data Stream for AWS.
Which data source do I have to select from the dropdown?
Account Cost
Code example:
"name": "account-cost",
"dataSourceConfig": {
"groupBy": [
"Key": "SERVICE"
"metrics": [
"AmortizedCost"
"granularity": "HOURLY",
"filter": {
"Dimensions": {
"Key": "SERVICE",
"Values": [
"AWS Cost Explorer"
"rowPath": [
"ResultsByTime",
"Groups"
"matches": {
"sourceType.0": {
"type": "equals",
"value": "AWS Account"
"metadata": [
"name": "ResultsByTime.TimePeriod.Start",
"displayName": "Date",
"shape": "date"
"name": "ResultsByTime.Groups.Keys.0",
"displayName": "Service",
"role": "label",
"shape": "string"
"name": "ResultsByTime.Groups.Metrics.AmortizedCost.Amount",
"displayName": "Cost",
"role": "value",
"shape": "currency"
"name": "ResultsByTime.Groups.Metrics.AmortizedCost.Unit",
"displayName": "Currency",
"shape": "string"
"name": "ResultsByTime.Estimated",
"displayName": "Estimated",
"shape": "boolean"
Parameters
name
Mandatory
The internal name of the data stream. Can be used the refer to this data stream in a tile's JSON instead of using the data stream's internal ID.
dataSourceConfig
Parameters
Note: You'll find a detailed description about what each parameter does and which values you can use in the AWS API docs: https://docs.aws.amazon.com/aws-cost-management/latest/APIReference/API_GetCostAndUsage.html
metrics | Mandatory | The metrics you want to return, for example |
granularity | Mandatory | The granularity of the data, for example |
groupBy | Optional | Use this if you want to group the data. For example, the default AWS Cost Data Stream groups the data by If you don't group by anything, you'll get the costs for your whole account. |
filter | Optional | Use this if you want to filter AWS costs by different dimensions. For example, if you only want to return the costs of the Cost Explorer service, you can filter to that service here. If you don't use any filter, all cost data for your account will be returned. |
matches
Parameters
Note: Defining the matches
parameter is mandatory.
With the matches
parameter you define for which objects the data stream will be shown in the UI. It works like this:
When you configure a tile, you have to choose its scope. If this scope contains objects you specified here in the matches
parameter, the data stream will be shown in the UI under Data Streams. If the scope doesn't contain objects specified here, the data stream will be hidden.
This keeps the UI clean and simple since you'll only see the data stream when it's relevant for the scope you chose. As a best practice you should limit the data stream to objects that make sense for the specific use case of this data stream.
Format for matches
//If you want to specifiy only one value of an object property//
"matches": {
"ObjectProperty": {
"type": "equals",
"value": "ValueOfTheObjectProperty"
//If you want to specifiy multiple values for an object property//
"matches": {
"ObjectProperty": {
"type": "oneOf",
"values": ["ValueOfTheObjectProperty1", "ValueOfTheObjectProperty2", "ValueOfTheObjectProperty3"]
Example for limiting a data stream to objects:
If you are using multiple values for the object property, you can decide if you want the data stream to be visible for objects that match all of the criteria or at least one of the criteria.
Lets say you have two values you want objects to have in order for the data stream to be visible for them:
a
SourceName
property with the valueAppDynamics
(meaning objects that come from the AppDynamics plugin)a
type
property with the valueapp
(meaning application objects)
If you want the data stream to be visible only for objects that match both of the criteria, your code would look like this:
"matches": {
"sourceName": {
"type": "equals",
"value": "AppDynamics"
"type": {
"type": "equals",
"value": "app"
If you want the data stream to be visible for objects that match at least one of the criteria, your code would look like this:
"matches": [
"sourceName": {
"type": "equals",
"type": {
"type": "equals",
"value": "app"
Note: If you run into errors when configuring the matches
parameter, check if you're dealing with a global data source.
Global data sources can't use specific objects in the matches
parameter. You can identify global data sources by their name, they have "Global" or "No Scope" added to their name.
There are two possible options for the matches parameter for global data sources:
"matches": "none", | When creating a tile, the Data Stream will be shown as long as no scope is selected. As soon as a scope is selected, the Data Stream will be hidden. |
"matches": "all", | When creating a tile, the Data Stream will be shown as soon as any scope is selected. |
rowPath
Parameter
Optional
SquaredUp expects data in table form, and here's where you define how the table with your return data will be structured.
The rowPath will tell SquaredUp which items you want to convert into rows.
Example:
Let's say your return data looks like this:
"generalInfo": "some info",
"results": [
"name": "object 1",
"tags": [
"tag 1",
"tag 2",
"tag 3"
"name": "object 2",
"tags": [
"tag 1",
"tag 4"
Now it depends on what data you want to base your table on, do you want rows per object or per tag?
If you want to see which objects have which tags, your rowPath
would be results
, and your table would look like this:
name | tags | generalInfo |
object 1 | tag 1, tag 2, tag 3 | some info |
object 2 | tag 1, tag 4 | some info |
If you want to turn each tag into a row and see to which objects they are applied, your rowPath
would be results.tags
tags | name | generalInfo |
tag 1 | object 1 | some info |
tag 1 | object 2 | some info |
tag 2 | object 1 | some info |
tag 3 | object 1 | some info |
tag 4 | object 2 | some info |
As you can see in the example, each parameter gets turned into a column and the items of the parameter you chose as the rowPath
will be turned into rows.
You might also have noticed in the example that the parameter generalInfo
was included in both cases. This is because after going through all parameters on the same level as your rowPath
, SquaredUp will move through all levels above the rowPath
and create columns from those parameters, too. Parameters on levels below the rowPath
won't be included in the table.
metadata
Parameter
Optional, but recommended
The metadata
parameters are used to describe columns in order to tell SquaredUp what to do with them. You can do multiple things with the metadata
parameters:
Specify how SquaredUp should interpret the columns you return and - to an extent - how their content displayed. You do this by giving each column a shape.
Filter out or just hide columns.
Only the columns you define in
metadata
will be returned in the results. This helps you to filter out columns you don't need. If you need the content of a column but don't want to display it, you can use thevisible
parameter.Give columns a nicely readable display name.
Assign a specific role to columns
The role you assign to a column tells SquaredUp the purpose of the column. For example, if you have two different columns that contain numbers, you need to assign the role
value
to the column that contains the actual value you want to use in your visualization.
Note: If you don't specify any metadata, all columns will be returned and SquaredUp will do its best to determine which columns should be used for which purpose. If you're returning pretty simple data, for example just a string and a number, this can work fine. But if you're returning two columns with numbers it gets trickier for SquaredUp to figure out which one is the value and which one is just an ID or some other number.
Parameters:
Tip: Before you start specifying metadata, leave them empty at first and get all the raw data with your new data stream once. In order to do this, finish creating your custom data stream without metadata and create a tile with this data stream. The Table visualization will show you all raw data.
This will give you an overview about all columns and their content and help you decide which columns you need and what their shapes and roles should be. It's also essential for getting the correct column name to reference in the name
parameter.
Use this information to go back to the data stream configuration and specifying the metadata.
name | Mandatory | Enter the name of the column you are referencing here. To find the name of a column, get the data from this data stream once without any metadata. See the tip above for how to do that. You'll see the column name when you hover over the column in the Table. |
displayName | Optional | Here you can give the column a user-friendly name for the UI |
shape | Recommended | The shape you assign to a column tells SquaredUp what the column contains (for example, a number, a date, a currency, a URL, etc.). Based on the shape SquaredUp decides how to display this column, for example to display a URL as a clickable link. Note: Please refer to the list of shapes below this table to see available shapes. |
role | Recommended | The role you assign to a column tells SquaredUp the purpose of the column. For example, if you have two different columns that contain numbers, you need to assign the role Note: Please refer to the list of roles below this table to see available roles. |
visible | Optional |
Use this if you need a columns content but don't need to display the column itself. Example: Column A contains the full link to a ticket in your ticket system. Column B contains the ticket ID. You want to use the ticket ID as a label for the link, turning the long URL into a much nicer to read "Ticket 123". This is why you need the content of column B, to assign it as a label for column A. But since the URL is now displayed as the ticket ID, it would be redundant to still display column B. This is why you hide column B with |
Basic types, like:
boolean
,date
,number
,string
Currency types that get displayed with two decimal values and their currency symbol (for example $23,45), like:
currency
(generic currency),eur
,gbp
,usd
Data types, like:
bytes
,kilobytes
,megabytes
Time types, like:
seconds
,milliseconds
,timespan
The status type :
state
Utility types, like:
customUnit
url
(will be displayed as a link)
Tip:
If a shape is configurable, you can edit how the shape displays data in the UI.
