Configuring an Agent for on-premises plugins
This article walks you through the steps for deploying, configuring and updating an Agent for on-premises plugins.
What is an Agent?
An Agent is a service that runs on a local machine and connects an internal service to SquaredUp. The Agent listens to the queue from SquaredUp and picks up tasks, for example running scripts to provide data that SquaredUp has asked for.
Prerequisites
The Agent needs to run on a Windows machine that has access to the data source for the on-premises plugin
Make sure the Agent is able to make outbound connections on port 443 (no inbound required) to SquaredUp and Microsoft APIs (Azure Relay).
How to deploy an Agent
Deploy the agent on a machine that has access to the service the plugin connects to.
Prerequisites for Agents
On a Windows machine, with access to the data source your plugin needs to use, extract the downloaded zip file.
Parameters to replace:
-ApiKey "key"
Mandatory Replace key
Optional To run the Agent as a domain service account (for example, for the SCOM plugin), provide the username as domain\username
where
key
Where
<ServiceName>
Start-Service -Name squpagent
or
Where
<DisplayName>
By default, the SquaredUp agent service uses the local system identity, but this can be changed to a domain service account if required, for example for the SCOM plugin.
Troubleshooting Agent Status
An Agent's status is shown in SquaredUpSettings > Relay as a green tick, amber exclamation mark, red cross or gray question mark. Hovering over the status will show information about the last connection.
If the Agent status is not green:
- Check that the Agent service is running (in Services on the server running the agent).
- Check that the API key is correct. In SquaredUp you can see the last 4 digits of the API key in Settings > Relay and compare this with what's in the
appsettings.json
file in the agent folder/Agent/transient/logs
. If necessary, you can edit the Agent and click Regenerate API Key to get a new key, then copy that into theappsettings.json
file.How to find the Agent folder location or Service name in Properties
- Check the Agent logs for any connectivity errors
- Check SquaredUp for any reported outages: https://squaredup.statuspage.io/
How to upgrade an Agent
The upgrade script needs to be run on the Windows machine running the Agent.
Go to Settings > Relay and download the latest release of the SquaredUp Agent zip file from the download icon under Options for your Agent.
On the Windows machine running the Agent, extract the downloaded zip file at the same level as (next to) the
Agent
folder.How to find the Agent folder location or Service name in Properties
Open PowerShell as an administrator and run the following command:
./Install-SQUPAgent.ps1 -upgrade
The upgrade script will stop the Agent service.
Make a note of the
ServiceName
for the next step. The upgrade script output shows theDisplayName
followed by theServiceName
in brackets:VERBOSE: Performing the operation "Stop-Service" on target "SquaredUp Cloud Agent (squpagent)".
Start the Agent service.
Where
<ServiceName>
or
Where
<DisplayName>
Check that configured plugins are available in the
Agent\transient\plugins
folder. The required connectors should be available in theAgent\transient\connectors
folder shortly after running the upgrade.Check that dashboards using built-in data streams work as expected.
If you have created any custom data streams (either manually or via configurable data streams) that depend upon the following plugins, you will need to update the
rowpath
and columnname
properties in each data stream to remove the“results."
suffix:SCOM Plugin
Custom PowerShell Plugin
VMware Plugin
Solarwinds Plugin
For example:
"name": "results.displayName"
would become"name": "displayName"
and
"rowPath": ["results"]
would become"rowPath": []
Once you have checked everything is working, remove the
backup
folder.The
backup
folder is created in case you need to roll-back: You can stop the service, delete or rename the existingAgent
folder, rename the backup folder toAgent
, and then restart the service.
How to remove an Agent
On the server running the Agent, locate the SquaredUp Agent service you wish to remove.
Services > SquaredUp Cloud Agent.
Right-click Properties and make a note of the Service name and the Path to executable.
If the Agent was configured without a suffix (i.e. a single instance of the Agent) then the service name will be squpagent. If a suffix was specified when the Agent was configured, a version of the suffix (with spaces and other special characters swapped for "-") will be appended to the name.
Copysc.exe delete squpagent
Where
squpagent
is replaced with the service name if it is not simplysqupagent
This will remove the service from Windows.
Finally, delete the Agent folder, as referenced in the Path to executable above.
