PagerDuty plugin
Monitor the Incidents and Alerts from your PagerDuty environment.
How to add the PagerDuty plugin
Create an API key in PagerDuty
Add the PagerDuty plugin to SquaredUp
Paste in the API key you created.
Plugin access levels
Access Level:
Click Save.
