Pingdom plugin
Monitor the health and performance of your Pingdom Checks.
How to add the Pingdom plugin
Create an API key in Pingdom
Add the plugin to SquaredUp
Paste in the API key you created.
Plugin access levels
Access Level:
Click Save.
