SCOM plugin
Monitor your SCOM environment, including Windows Computers, Enterprise Applications and more.
Note: This plugin is an on-premises plugin.
An on-premises plugin connects a service running in your internal network to SquaredUp. They require an agent installed on a machine that has access to your internal network.
How to add the SCOM plugin
Configure and deploy an agent
If you have already created an agent in SquaredUp that you can use for this plugin, you can skip this step and choose the agent group you want to use while adding the plugin.
Deploy the agent on a machine that has access to the service the plugin connects to.
Prerequisites for Agents
The Agent needs to run on a Windows machine that has access to the data source for the on-premises plugin
Make sure the Agent is able to make outbound connections on port 443 (no inbound required) to SquaredUp and Microsoft APIs (Azure Relay).
On a Windows machine, with access to the data source your plugin needs to use, extract the downloaded zip file.
Parameters to replace:
-ApiKey "key"
Mandatory Replace key
Optional To run the Agent as a domain service account (for example, for the SCOM plugin), provide the username as domain\username
where
key
Where
<ServiceName>
Start-Service -Name squpagent
or
Where
<DisplayName>
By default, the SquaredUp agent service uses the local system identity, but this can be changed to a domain service account if required, for example for the SCOM plugin.
Configure the agent for the SCOM plugin
Why do agents for the SCOM plugin need special configuration?
The SquaredUp agent service uses the local system identity by default. SCOM uses Windows authentication which requires at a minimum Network Service or a Domain User account, the agent you use for the SCOM plugin needs to have its service identity changed to such an account.
Permissions for the service account:
Consider which objects you want to import and set the permissions for the service account accordingly. As the SCOM plugin supports SCOM RBAC you can use scoping in the user role for the account in SCOM to control which objects will be imported.
You need to manually add the service account to the opsmgreader role of the Data Warehouse in the SCOM console see Manually creating the Data Warehouse permissions
where
key
Add the SCOM plugin in SquaredUp
Display Name:
SCOM Management Server:
Enter your SCOM management server as a FQDN, for example
server.domain.local
Dashboard Server SCOM Edition URL:
Optional. If you use Dashboard Server SCOM Edition, you can enter the URL to your instance. This will create a link from a SCOM object in SquaredUp to the same object in your Dashboard Server SCOM Edition.
Enter the URL to the root domain including https, for example:
https://myserver.mydomain/SquaredUpv5/
Agent Group:
Plugin access levels
Access Level:
Click Save.
Using the SCOM plugin
Data Streams
There are two types of data streams available for this plugin
Data streams installed with the plugin
Configurable data streams see Using Configurable data streams with the SCOM plugin
Metric
This data stream calls an API endpoint to get metrics from your SCOM instance, and allows you to enter a custom object name, counter name and instance name.
Scope to a SCOM item that supports metrics
Select + Metric from the data stream list
Enter an Object Name, for example:
LogicalDisk
Enter a Counter Name, for example: Free Megabytes
Optionally, enter an Instance Name
Optionally, enter the Top N number of items you want to see
Check Sort descending if you want to sort the results descending instead of ascending
