Solarwinds plugin
Monitor key metrics and states from your SolarWinds environment.
Note: This plugin is an on-premises plugin.
An on-premises plugin connects a service running in your internal network to SquaredUp. They require an agent installed on a machine that has access to your internal network.
Prerequisites
The Solarwinds plugin requires a user account (username and password) to access the Solarwinds API. The user account is created and managed under Settings > All Settings > User Accounts > Manage Accounts in the Solarwinds console. Creating a user with default permissions (i.e. no admin rights) is usually sufficient.
How to add the Solarwinds plugin
Configure and deploy an agent
If you have already created an agent in SquaredUp that you can use for this plugin, you can skip this step and choose the agent group you want to use while adding the plugin.
Deploy the agent on a machine that has access to the service the plugin connects to.
Prerequisites for Agents
The Agent needs to run on a Windows machine that has access to the data source for the on-premises plugin
Make sure the Agent is able to make outbound connections on port 443 (no inbound required) to SquaredUp and Microsoft APIs (Azure Relay).
On a Windows machine, with access to the data source your plugin needs to use, extract the downloaded zip file.
Parameters to replace:
-ApiKey "key"
Mandatory Replace key
Optional To run the Agent as a domain service account (for example, for the SCOM plugin), provide the username as domain\username
where
key
Where
<ServiceName>
Start-Service -Name squpagent
or
Where
<DisplayName>
By default, the SquaredUp agent service uses the local system identity, but this can be changed to a domain service account if required, for example for the SCOM plugin.
Add the Solarwinds plugin in SquaredUp.
Display Name:
Server URL:
Enter the URL to your Solarwinds environment in the following format:
https://server.domain.name
Server Port:
If you don't use the default port 17778, enter your port here. If you use the default port 17778, you don't need to change this field.
Username and Password:
Enter your username and password for your Solarwinds environment.
Agent Group:
Plugin access levels
Access Level:
Click Save.
Using the Solarwinds plugin
Data Streams
There are two types of data streams available for this plugin
Data streams installed with the plugin
Configurable data streams see Using Configurable data streams with the Solarwinds plugin
Custom data streams, see How to create custom data streams for Solarwinds
Metric
This data stream calls the /SolarWinds/InformationService/v3/Json/Query
endpoint with a pre-set query, and allows you to enter a custom node type and metric.
Scope to a SolarWinds item that supports metrics
Select + Metric from the data stream list
Enter a Node Type, for example:
Nodes
Enter a Metric, for example:
CPULoad
Health State
endpoint with a pre-set query, and allows you to enter a custom node type.
Scope to a SolarWinds item that supports health states
Select + Health State from the data stream list
Nodes
Custom SWQL
This data source calls the /SolarWinds/InformationService/v3/Json/Query
endpoint, and allows you to enter a custom SWQL query. See SolarWinds: Use SolarWinds Query Language (SWQL) in the Orion Platform
A good starter JSON for this data stream is as follows:
"name": "customSwql",
"dataSourceConfig": {},
"rowPath": ["results"],
"matches": {
"sourceType": { "type": "equals", "value": "SolarWinds Host" }
"metadata": []
SWQL
This is the SWQL query that is performed on the scoped item. It can be added to the dataSourceConfig
like so:
"swql": "SELECT something FROM somewhere WHERE something like something"
