Dashboards
Dashboards are where you add tiles to show data as tables or graphs, and where you configure monitoring.
Dashboards refresh once a minute.
Editing existing dashboards
SquaredUp comes with some sample dashboards and sample data to allow you to see the visualizations available. You can edit these dashboards and tiles, as you can with the sample dashboards installed with any data source.
To edit a dashboard click the Edit pencil button at the top of the screen.
Then to edit a tile click the Edit tile pencil button at the top of a tile.
You can also select Clone tile or Delete tile.
Creating new dashboards
Navigate to the workspace where you want the dashboard, or create a new workspace by clicking + Create workspace in the dropdown after clicking on the current workspace name on the left-hand menu.
Click the + next to Dashboards on the left-hand menu to create a new dashboard.
Rename the dashboard by overwriting the New Dashboard title.
Configuring a tile on a dashboard
There are three types of tile that you can configure:
Data – visualize data on your dashboard, see Configuring a data tile
Image – add an image to your dashboard, see Configuring an image tile
Text – add text to your dashboard, see Configuring a text tile
On the dashboard, hover where you'd like to place a visualization, and click the + that appears. Click on the Data icon, the tile editor will appear.
The tile editor allows you to configure the data from your data sources and display it in any way you wish. Steps may vary depending on which data stream you select. You can add a title and description for your tile at the top of tile editor.
The first step is to select which data stream you want to use. You will see a list of all available data streams for your indexed data sources. If you need to index a new data source, select the + icon next to Data Source filter.
You can search for data streams at the top, or filter data streams by Data Source, Data Stream Type or Object Scope.
For each data stream in the list of available data streams you will see:
Name of the data stream
Data source
Data stream type (Scoped or Global)
Object scope
Whether the data stream is configurable – configurable data streams are represented by a cog icon. User-configured data streams are represented by a user icon.
Select the data stream that you want to use and then click Next.
Help with configuring data streams specific to your data source can be found in each specific data source article:
The Objects tab of the tile editor will only need to be completed if you selected a Scoped data stream in the previous step. You will see a list of all available objects for the selected data stream.
You can search for objects at the top, or filter objects by Data Source or Type. To narrow results down further, additional filters can be used by selecting Add Filter.
For each object in the list of available objects you will see:
Name of the object
Data source
Type
Select the objects that you want to add by using the checkbox next to each object name.
Alternatively, turn on Dynamic selection in the top right corner. Dynamic selection will select all objects that match the filters, including objects that are indexed at a later date.
Once you have finished selecting objects, click Next.
The Query tab of the tile editor will only need to be completed if you selected a Configurable data stream. Complete each field to configure the data stream how you wish.
Query fields will vary depending on which configurable data stream you selected.
Click Next.
Select a timeframe for the tile. By default, the timeframe is set to the dashboard timeframe.
Filtering
Data can be filtered according to whether data in a column meets or does not meet specified text or numerical value conditions. Depending on the data you are filtering, available options include: Equals, Not equals, Contains, Doesn't contain, Less than, Greater than, Before now, After now.
Dates can be filtered by Before now or After now (e.g. to show overdue orders). Text matching is case sensitive.
You are able to add multiple filter conditions. Available options are:
AND – all conditions must be satisfied (e.g.
Status-Equals-Closed
ANDType-Equals-Question
).OR – any condition can be satisfied (e.g.
Status-Equals-Pending
ORStatus-Equals-Closed
Group by
For example, for AWS cost data you might Group bylabel
, choose Aggregation typeTotal
with Aggregation columnAmount
, to show a table or bar chart of cost per label.
Which columns are available depends on the data stream you chose.
Bucket by
If you group by a time column, and further grouping is possible, then the Bucket by dropdown will appear, which allows you to control how the time data is grouped, for example by hour
, day
, month
etc.
Aggregation type and column
Using this dropdown you can choose how to summarize your data, for example as a count
, average
or total
For example, for a Bar Chart of ticket data you might Group by Date created
, choose Bucket byDay
with Aggregation type Count
, to show a line graph of tickets per day. Or for a Bar Chart of Azure Resource Group cost you might Group byTimestamp
, Bucket byDay
, Aggregation typeTotal
and Aggregate columnCost
Select the visualization for your tile. Which visualizations are offered to you depends on the data available, for example Line Graph will only be offered if there is time series data.
Bar Chart settings
X-axis data | Choose which data to show on the x-axis. Auto <column> shows the column which was selected automatically for you, usually a time field for the x-axis. |
Y-axis data | Choose which data to show on the y-axis. Auto <column> shows the column which was selected automatically for you, usually a numerical field for the y-axis. |
Y-axis range | Auto - graph is fitted to the data automatically Percentage - shows 0-100 Fit to data from zero - shows from 0 to the data maximum Custom - allows you to specify the min and max |
X-axis label | Allows you to override the default and enter a label, for example Date or Time . |
Y-axis label | Allows you to override the default and enter a label, for example Tickets or ms . |
Blocks settings
Sublabel | Choose the sublabel to be shown beneath the main block label |
Columns | Set the number of columns the blocks are displayed in |
Reset - reverts to the default settings.
Gauge settings
The Gauge visualization shows a single value, often a percentage, in relation to minimum and maximum values. Monitoring can be added so the gauge color changes based on your configured parameters.
Data | Choose which column or count to use as the value for the gauge. Auto <column> shows the column which was selected automatically for you. |
Range | Specify the min and max of the gauge |
Label | Add a label to be shown beneath the gauge |
Monitoring | You can configure Monitoring (from the Monitoring tab) and then the colors configured for the conditions will show on the gauge. Check that the Data chosen in the Visualization (e.g. count ) and the Value (and Column where applicable) that you are Monitoring (e.g. count ) are as intended. |
Stacked Bar settings
Type | Specify how to group bars, either stacked in a single bar or grouped as separate bars. |
Mode | Percentage mode displays a series as a percentage of the overall bar, only available for Grouped charts. |
Layout | Vertical or horizontal |
X-axis grouping | Choose how the stack is split into segments, usually a label or a string. |
Line Graph settings
Data points | This shows where the data points are on the line. Useful to identify missing points, or detail for changing data. |
Shading | Adds shading below each line. |
Scalar settings
Source Column | Choose the column to be used. The default is auto , where the column is chosen by the visualization. |
Label | Enter a label, for example Tickets or ms . |
Show formatted value | This shows a simplified value. Toggle to Off to show the raw value. (On by default) |
Table settings
Sort order | Click and drag a column name to change their order. |
Hide/show | Click on the Toggle visibility eye button to hide or show a column. |
Resizing columns | Use the handle on each column of the table to change the width. Changes will be saved while in the tile editor or in dashboard edit mode. |
Filtering, grouping and sorting of the data can be configured in the data stream advanced settings.
These steps describe the simple tile editor. Advanced users might like to try the SQL Analytics editor see SQL Analytics (Beta).
You can also configure Monitoring and KPIs in the tile configuration:
Image tiles can be used to display company logos on dashboards. You can also use Image tiles to add diagrams and additional context to your dashboard, e.g., Visio images. The Image tile allows you to enter the URL to an image hosted elsewhere. Select the Image icon to start configuring the tile.
Image URL
Enter the URL of the image that you would like to embed.
Image Description
Optionally, enter a description for the image. This will be shown to screen readers and if you hover over the image on the dashboard.
Click Save.
The image will be rendered to fill the tile (without stretching). You can resize the tile by dragging the bottom right corner of the tile. The image will automatically scale should you wish to resize the tile.
Text tiles can be used to split the dashboard up into different sections. You may also want to use Text tiles to inform users who they should contact with an issue or what action they should take. Select the Text icon to start configuring the tile.
Content
Enter the text that you would like to appear on your dashboard.
Fit to tile
Select whether you would like your text to fit to the size of the tile. By default, Fit to tile is set to on.
Font size
This is only required if you set Fit to tile as off.
Select the font size that you would like your text to appear in.
Text alignment
Select the alignment of the text within the tile. Available options are: Left, Center, Right.
Click Save.
You can resize the tile by dragging the bottom right corner of the tile. If you set Fit to tile as on, the text will automatically scale should you wish to resize the tile.
Dashboard Settings
Reorder dashboards
By default, dashboards appear in alphabetical order on the left-hand menu within a workspace. You are able to reorder the list of dashboards to suit your needs. You may want to do this if you are frequently using specific dashboards and want them to be at the top of the list of dashboards.
To reorder the dashboards, hover over the drag (hamburger) icon to the left of the dashboard name and then drag the dashboard to where you would like it to appear in the list. Changes are saved automatically.
Only members of the Admin group, users with Full Control or users with Editor permissions are able to change the order of the dashboards within a specific workspace.
Dashboard Timeframe
Tiles can be configured to:
Share
The Share button is on every dashboard and allows you to share the dashboard URL with colleagues.
Ticking Collapse navigation appends ?hideNav=true
to the URL to show the dashboard full screen without any navigation, which can be useful for wall monitors etc.
More options
The More options ellipsis button shows you buttons to:
Clone – create a copy of the whole dashboard, for example, if you wish to copy the layout but change the information slightly.
Edit JSON – for advanced editing.
Delete – this permanently removes the dashboard and cannot be undone.
