Atlassian Statuspage plugin
This plugin returns data from any publicly accessible Atlassian Statuspage.
How to add the Atlassian Statuspage plugin
Display Name:
Organization Name:
Enter the name of the Statuspage's organization.
Atlassian Statuspages follow the following format: https://OrganizationName
.statuspage.ioNote: You don't need to enter the URL, just the
OrganizationName
.Leave the checkbox for Automatically create a workspace ticked, this will create a new workspace for this plugin containing out of the box dashboards and scopes.
Plugin access levels
Access Level:
Click Save.
