Datadog plugin
Monitor your Datadog environment.
How to add the Datadog plugin
Display Name:
Site:
Select the Datadog site that you use to log into your Datadog instance.
API Key:
Open a new tab and log into your Datadog instance. Create an API key and copy it. Return to the SquaredUp tab and paste the API key into this field.
Application Key:
Open the tab with your Datadog instance again, create an Application key, and copy it. Return to the SquaredUp tab and paste the Application key into this field.
Plugin access levels
Access Level:
Click Save.
Using the Datadog plugin
Data Streams
There are two types of data streams available for this plugin
Data streams installed with the plugin
Configurable data streams see Using Configurable data streams with the Datadog plugin
Metric
This data stream calls the /api/v1/query
endpoint with a pre-set query, and allows you to enter a custom metric name.
Scope to a Datadog object that supports metrics, for example hosts.
Click + Metric from the data stream list
Type a Display Name for the new data stream
Type a Metric, for example:
system.cpu.user
See Datadog: Metrics
