OpenWeatherMap plugin
Provides weather forecast data from OpenWeatherMap. Depends on plugins that create location entities with a latitude and longitude.
Note: You need the Geodata plugin to be able to use the OpenWeatherMap plugin. The Geodata plugin will provide the country and city objects while the OpenWeatherMap plugin will provide the Data Streams to use with these objects, for example to show the current temperature for a list of cities.
The Geodata plugin creates objects for countries, cities, and currencies which can be used in Data Streams that come from other plugins.
It's a utility plugin that can be added without entering any credentials, which means you don't have to create an API key, user account, or anything like that.
How to add the OpenWeatherMap plugin
Display Name:
API Key:
Create an API key in your OpenWeatherMap account.
Note:
OpenWeather offers free and payed accounts. Depending on the account, there can be a rate limit for how many API calls you can make per minute. If you exceed your limit, tiles that use the OpenWeatherMap plugin will show an error. Here you'll find an overview about their account options, and you can sign up for the one that fits your needs: https://openweathermap.org/price
Plugin access levels
Access Level:
Click Save.
If you haven't added the Geodata plugin yet, add the Geodata plugin. To be able to use the Data Streams that come with the OpenWeatherMap plugin, you need city or country objects from the Geodata plugin. See Geodata plugin
Using the OpenWeatherMap plugin
Create a scope using the Geodata plugin
In the OpenWeatherMap workspace click Scope on the left hand side.
Under Plugins click on Geodata.
Under Types click on City.
Search for the city you want to show weather for, for example your nearest city.
Click Next.
Give your scope a name, perhaps the city name, for example
London
Create a tile
Under Scopeclick on Existing and then on the scope you created, for example London.
Click on the data stream for the weather you want to display, for example Current Temperature.
Click on the visualization you want, for example Scalar.
Troubleshooting tiles that use the OpenWeatherMap plugin
Error because of exceeded API call rate limit
