MSSQL plugin
The plugin is available as a Cloud plugin and also as an on-premises plugin. This plugin allows for the connection from the on-premises SquaredUp agent to any MSSQL instance which is available to connect to with SQL Login.
An on-premises plugin connects a service running in your internal network to SquaredUp. They require an agent installed on a machine that has access to your internal network.
How to add the MSSQL plugin
You will only need to configure and deploy an agent if you adding the MSSQL on-premises plugin. If you want to add the MSSQL Cloud plugin, you only need to follow the steps detailed in Add the MSSQL plugin in SquaredUp.
Configure and deploy an agent
If you have already created an agent in SquaredUp that you can use for this plugin, you can skip this step and choose the agent group you want to use while adding the plugin.
Deploy the agent on a machine that has access to the service the plugin connects to.
Prerequisites for Agents
The Agent needs to run on a Windows machine that has access to the data source for the on-premises plugin
Make sure the Agent is able to make outbound connections on port 443 (no inbound required) to SquaredUp and Microsoft APIs (Azure Relay).
On a Windows machine, with access to the data source your plugin needs to use, extract the downloaded zip file.
Parameters to replace:
-ApiKey "key"
Mandatory Replace key
Optional To run the Agent as a domain service account (for example, for the SCOM plugin), provide the username as domain\username
where
key
Where
<ServiceName>
Start-Service -Name squpagent
or
Where
<DisplayName>
By default, the SquaredUp agent service uses the local system identity, but this can be changed to a domain service account if required, for example for the SCOM plugin.
Display Name:
Username:
Enter the SQL login username
Password:
The SQL login password
Server:
The server address or IP which to connect to. Do not include a port with the SERVER value.
If you are adding the MSSQL on-premises plugin, the server must be accessible from the machine running the SquaredUp on-premises agent.
Database:
The name of the database which to initially connect to. Any queries executed without a database explicitly set will be run against this database.
Port:
The port to use to connect to SQL. The default is 1433, but can be changed as needed.
Encrypt connection:
If the destination server supports encryption then tick this to set it as required for the connection. This setting should be ticked when connecting to a managed Azure SQL Database.
Trust server certificate:
Tick this to bypass certificate checks, and trust the server certificate. This is most commonly used in development and non-production environments using self-signed certificates.
Object Query (optional):
The MSSQL Server Connection can create objects in the Knowledge Graph import and these can be used to create context sensitive objects and drill-downs.
Object Query
These plugins support the creation of objects from a database query. The resulting table must contain sourceId, name, and type fields. Additional fields are allowed, and any non-null fields will be included with the object when imported into the Knowledge Graph.
A sample query result is below:
sourceId
name
type
initials
operating_system
abeLincoln
Abraham Lincoln
user
AL
server_1
Infra-SQL01.local
server
windows
In the above sample table two objects will be created in the Knowledge Graph. The first will be of type user and have a sourceId of abeLincoln and a single property for initials. The operating_system attribute will not be added to this object as it has a null property. The second object created will be a server with sourceId server_1 and a single property of operating_system.
Relationship Query (optional):
If you are creating objects with the Object Query set in the previous step, you can relate those objects in the Knowledge Graph.
Relationship Query
Along with an Object Query an additional Relationship Query can also be used. The result of this query must contain the fields inV, outV, and label. The rows of this result will be converted to relationships in the Knowledge Graph.
outV
label
inV
abeLincoln
own
server_1
After the import is complete the two objects created from the Object Query will now be linked, with Abraham Lincoln owning Infra-SQL01.local
Agent Group:
Plugin access levels
Access Level:
Click Save.
Using the MSSQL plugin
Add a dashboard and go into the configuration of a tile.
Add a scope. For example:
Plugin: MSSQL On-Premises
Type: MSSQL Connections
Create a data stream by clicking on one of the customizable data streams.
Creating data streams for the MSSQL plugin
This plugin allows you to configure your own data streams.
When using the plugin to create data streams you have the option to create three different query types, as detailed below. The use of dynamic {{mustache}} properties is supported and is detailed following the types.
Custom Table Query
This allows for any tabular data to be pulled into to SquaredUp and be displayed in a standard table.
Custom Metrics Query
This configurable data stream type allows for data to be displayed in a visual format, such as a line graph. When writing a query for use as a Metrics query, the below three columns are mandatory and all others will be ignored.
Column Name (case sensitive) | Content |
label | The label for the value passed in, for example ‘Percent Utilization’. Each distinct ‘label’ value will get its own line color which includes only values for that label. |
timestamp | A DateTime value of when this reading occurred |
value | A numerical non-null value to be visualized |
Custom State Query
This configurable data stream allows for data to be displayed as a state tile (Red, Yellow, or Green blocks). When writing a query for use in a State query the below three columns are mandatory and all others will be ignored.
label | The label for the state passed in, for example ‘Deliveries’. These ‘label’ values must be distinct and will each produce their own status block |
id | If this state will be tied to an object, then that object’s sourceId should be used, otherwise passing the ‘label’ value a second time will work effectively. |
state | The state of the labeled object, options are ‘Success’, ‘Warning’, ‘Error’, and ‘Unknown’ |
Available Properties ({{mustache}})
timeframe
All of the properties in the calling event payload are passed through to the template builder with the addition of below three properties.
• durationSeconds
• durationMinutes
• durationHours
Example
Parameter | Replacement value | Type |
{{timeframe.start}} | 2022-03-13T19:45:00.000Z | string |
{{timeframe.unixStart}} | 1647200700 | number |
{{timeframe.end}} | 2022-03-14T19:45:00.000Z | string |
{{timeframe.unixEnd}} | 1647287100 | number |
{{timeframe.enum}} | last24hours | string |
{{timeframe.interval}} | PT15M | string |
{{timeframe.durationSeconds}} | 86400 | number |
{{timeframe.durationMinutes}} | 1440 | number |
{{timeframe.durationHours}} | 24 | number |
Select CustomerName, Order from dbo.Orders where orderDT > DateADD(mi, -{{timeframe.durationMinutes}},GetDate())
sourceIds
This is a unique property as some pre-processing occurs within the plugin to modify the values. sourceIds will return a list of all the targeted nodes sourceId elements, concatenated with commas and string delimiters for TSQL friendly systems.
Example
{{sourceIds}} | 'idOne','idTwo','idThree' | string |
Select CustomerName, Order from dbo.Orders where customerId IN ({{sourceIds}})
sourceId
This will return the sourceId of the first target node in the query. While not as powerful as the sourceIds value, it works for systems that don't support TSQL syntax and will still allow drill-down behavior
Example
{{sourceId}} | idOne | string |
Select CustomerName, Order from dbo.Orders where customerId = '{{sourceId}}'
targetNodes
This property represents the targetNodes on the calling event with the small addition of a first and last property on the respective nodes. This allows for Mustache templates to do a couple tricks, as noted below.
Example
{{targetNodes.0.sourceId}} | idOne | string |
{{#targetNodes}}'{{sourceId}}'{{^last}},{{/last}}{{/targetNodes}} | 'idOne','idTwo','idThree' | string |
Select CustomerName, Order from dbo.Orders where customerId = '{{targetNodes.0.sourceId}}'
Select CustomerName, Order from dbo.Orders where customerId IN ({{#targetNodes}}'{{sourceId}}'{{^last}},{{/last}}{{/targetNodes}})
