Data Streams
What is a Data Stream?
How do I get Data Streams?
Pre-configured data streams - some plugins come with pre-configured data streams that are imported when you add the plugin.
Configurable data streams - some plugins allow you to create new data streams using a form.
Advanced users can also write their own custom data streams (or edit a data stream created from a configurable data stream) see Custom Data Streams.
Using Data Streams
When adding or editing a tile on a dashboard you need to configure a scope, data stream and visualization. See Dashboards
Select the data stream that answers the question you have about the objects in the scope.
Which data streams are offered to you depends on the objects in the scope. Every object has been imported from a plugin, together with data streams that make sense for those objects. If you pick a scope that contains objects from different plugins you'll see all data streams from those plugins. If you pick a scope with objects that came from a plugin without data streams you'll only see the pre-installed data streams that are always available in SquaredUp, even if you never imported any data streams.
Data Stream Advanced Settings
Advanced settings for each data stream can be found by clicking Configure next to the data stream name.
Filtering
Data shown can be filtered according to whether data in a column equals or does not equal a specified text or numerical value. Dates can be filtered by Before now or After now, for example to show overdue orders. Text matching is case sensitive.
Group by
For example, you might Group byservice
, choose to Aggregate columnamount
with Aggregation typeTotal
, to show a table of cost per service.
Which columns are available depends on the data stream you chose.
