Pendo plugin
Visualize your Pendo report data and custom aggregation queries.
How to add the Pendo plugin
Create an Integration Key in Pendo
Create an Integration Key in Pendo, see Pendo: Authentication
Copy and note the Integration Key somewhere safe.
Add the Pendo plugin to SquaredUp
Display Name:
Integration Key: Enter the key you created in Pendo.
Plugin access levels
Access Level:
Click Save.
Using the Pendo plugin
Data Streams
There are two types of data streams available for this plugin
Data streams installed with the plugin, see Using the Pendo Reports data stream
Configurable data streams see Using Configurable data streams with the Pendo plugin
This data stream calls the /report/{reportId}/results.json
endpoint.
Scope to a Pendo Report
Select Pendo Report from the data stream list
Number of Visitors
This data stream calls the /aggregation
endpoint.
Scope to a Pendo Organization
Select + Number of Visitors
Enter a Pendo Segment Id
Custom Aggregation Query
endpoint and allows you to enter a custom Pendo aggregation query.
Select + Custom Aggregation Query
Enter Aggregation Query, for example:
"requestId": "account-list",
"pipeline": [
"source": {
"accounts": null
