Dynatrace plugin
Monitor the Applications and Synthetic Transactions from your Dynatrace environment.
Note: If you're not using a cloud-based Dynatrace environment and instead are running Dynatrace in your internal network, you want to use the on-premises Dynatrace plugin, see How to add the Dynatrace on-premises plugin.
Prerequisites
Generate a new token in Dynatrace and save the token to use when adding the plugin to SquaredUp later, see Dynatrace: Generate an access token
How to add the Dynatrace plugin
Display Name:
Base URL:
Enter the Base URL to your Dynatrace environment, for example
https://myEnvironmentID.live.dynatrace.com/
API Key:
Enter the API key you created in your Dynatrace environment.
Leave the checkbox for Automatically create a workspace ticked, this will create a new workspace for this plugin containing out of the box dashboards and scopes. Click Save.
Note: This plugin is an on-premises plugin.
An on-premises plugin connects a service running in your internal network to SquaredUp. They require an agent installed on a machine that has access to your internal network.
Configure and deploy an agent
If you have already created an agent in SquaredUp that you can use for this plugin, you can skip this step and choose the agent group you want to use while adding the plugin.
Deploy the agent on a machine that has access to the service the plugin connects to.
Prerequisites for Agents
The Agent needs to run on a Windows machine that has access to the data source for the on-premises plugin
Make sure the Agent is able to make outbound connections on port 443 (no inbound required) to SquaredUp and Microsoft APIs (Azure Relay).
On a Windows machine, with access to the data source your plugin needs to use, extract the downloaded zip file.
Parameters to replace:
-ApiKey "key"
Mandatory Replace key
Optional To run the Agent as a domain service account (for example, for the SCOM plugin), provide the username as domain\username
where
key
Where
<ServiceName>
Start-Service -Name squpagent
or
Where
<DisplayName>
By default, the SquaredUp agent service uses the local system identity, but this can be changed to a domain service account if required, for example for the SCOM plugin.
Add the Dynatrace plugin in SquaredUp
Display Name:
Base URL:
Enter the Base URL to your Dynatrace environment in the following format:
https://your-domain/e/your-environment-id/
API Key:
Agent Group:
Plugin access levels
Access Level:
Click Test and save to validate the plugin configuration.
Testing outcomes
Testing passed with warnings – warnings will be listed and potential fixes suggested. You can still use the plugin with warnings. Select Save with warnings if you believe that you can still use the plugin as required with the warnings listed. Alternatively, address the issues listed and then select Rerun tests to validate the plugin configuration again. If the validation now passes, click Save.
Testing Failed – errors will be listed and potential fixes suggested. You cannot use the plugin with errors. You are able to select Save with errors if you believe that a system outside of SquaredUp Cloud is causing the error that you need to fix. Alternatively, address the issues listed and then select Rerun tests to validate the plugin configuration again. If the validation now passes, click Save.
You can edit any plugin configurations at any time from Settings > Plugins.
Using the Dynatrace plugin
Data Streams
There are two types of data streams available for this plugin
Data streams installed with the plugin, see Tips for using the Dynatrace data streams
Configurable data streams see Using Configurable data streams with the Dynatrace plugin
Metric
This data stream calls the /api/v2/metrics/query
endpoint with a pre-set query, and allows you to enter a custom metric key.
Scope to a Dynatrace item that supports metrics
Select + Metric from the data stream list
Select a Metric Key from the dropdown, for example:
builtin:service.response.time
Optionally, tick Show only most recent value if you want to only show the one latest value. If this is not ticked then any historical data is shown, so line graphs over time are possible. If you are showing historical data, you might like to name your data stream to indicate this, for example
Availability History
This plugin comes with several data streams that you can use in the tiles on your dashboards. Here you'll find tips and ideas for using these data streams to display the data you're interested in.
Using the Health data streams
You can visualize the status of your hosts or services with the Dynatrace Health data streams. Available Health data streams are:
Application Health
Browser Monitor Health
Database Health
HTTP Monitor Health
Host Health
Service Health
You can visualize the data as health state blocks. You will need to set up the requirements for potential problems related to the health of your hosts and services from your Dynatrace account. SquaredUp Cloud will then visualize the health state block as red/green based on the reported problems from Dynatrace. If the health state block displays as green, there are no problems with the health of your hosts or services. If the health state block displays as red, there are problems associated with the health of your hosts or services. Alternatively, you can visualize the data as a table in SquaredUp Cloud.
