Usage plugin
The Usage plugin lets you keep track of your SquaredUp usage. It comes with Data Streams that enable you to display stats like number of workspaces, number of dashboards, number of data queries, number of users, etc.
When you add this plugin, your SquaredUp organization will be added as an organization object you can scope to. When you create a scope with the organization object, you'll see the Data Streams for this plugin.
When you click on your user profile, you can see the name of your organization on top of the menu:
Tip: Data Streams that are named "metric" (like "Number of objects indexed metric") adapt to the dashboard timeframe and give you a history of usage over time.
How to add the Usage plugin
In SquaredUp browse to Settings > API Keys > Create new API Key. Copy the API key to your clipboard.
Display Name:
API key: Paste the API key here.
Plugin access levels
Access Level:
Click Save.
