Cloudflare plugin
Monitor the health and performance of your Cloudflare websites.
How to add the Cloudflare plugin
Display Name:
API Token:
Go to your Cloudflare account, create an API token using the template Read all resources, and paste it in here. If you need help creating an API token, please refer to the Cloudflare documentation: Cloudflare: Creating API tokens
Plugin access levels
Access Level:
Click Test and save to validate the plugin configuration.
Testing outcomes
Testing passed with warnings – warnings will be listed and potential fixes suggested. You can still use the plugin with warnings. Select Save with warnings if you believe that you can still use the plugin as required with the warnings listed. Alternatively, address the issues listed and then select Rerun tests to validate the plugin configuration again. If the validation now passes, click Save.
Testing Failed – errors will be listed and potential fixes suggested. You cannot use the plugin with errors. You are able to select Save with errors if you believe that a system outside of SquaredUp Cloud is causing the error that you need to fix. Alternatively, address the issues listed and then select Rerun tests to validate the plugin configuration again. If the validation now passes, click Save.
You can edit any plugin configurations at any time from Settings > Plugins.
