SQL Analytics (Beta)
SQL Analytics allows you to carry out advanced manipulation of data using a SQL query before you visualize it.
For example:
You might ask 'What is the average time difference between a ticket created and resolved?' You can use SQL to calculate the difference between the ticket created and resolved time, then you can visualize the Mean Time To Resolution (MTTR).
For AWS CloudWatch data you might want to know 'What is the 95% percentile response time of my microservice?' use SQL to query the data, and then show the Service Level Indicator (SLI).
You can also combine data sources and query them before visualizing the data. You might combine your Azure Cost data with your Azure Monitor data and ask 'What is the potential cost saving of turning off my unused VMs?'
Switch to the Analytics Editor
When editing a tile click on Switch to Analytics at the top of the screen. This changes your view from the simple tile editor into the more advanced Analytics Editor. It's best to decide whether you want to stick with the SQL Analytics editor for a particular tile, or with the simple editor, rather than switching between the two.
If you exit out of the Analytics Editor, choosing to revert to using the simple editor for this tile, then you lose your SQL queries and tables, as only the first table is saved.
Instead of the Scope - Data Stream - Visualization tile editing view that you're used to in the simple tile editor, in the Analytics Editor you have Tables - SQL Query - Visualization down the left hand side.
As with the simple editor, you can still add Monitoring or KPIs, or view the Raw (raw data) or Code (code editor).
Tables
A table is the scope and the data stream combined. If you had already selected a scope and data stream in the simple tile editor this will be shown as your first table, which you can rename if you wish. For example, if you are looking at Zendesk tickets you might rename table1
to tickets
You can add new tables, which allows you to add in further data. For a new table configure the scope and data stream to show the data you want.
Each table can be configured to use a different timeframe, if required and it makes sense for that data, or use the dashboard timeframe.
Tiles can be configured to:
SQL Query
This uses standard Structured Query Language (SQL).
When you first go into the SQL Analytics editor the SQL query will show everything from the first table, as a simple query:
Select * FROM tickets
You can edit this query to be something more complex. For example, to find the average difference between two different times you can use DATEDIFF
and display this it as 'MTTR':
SELECT AVG(DATEDIFF(HOUR, created_at, updated_at)) AS MTTR FROM tickets
You can also use SQL to query data from more than one table, or combine data with a JOIN etc.
Visualization
Select the visualization for your tile. Which visualizations are offered to you depends on the data available, for example Line Graph will only be offered if there is time series data.
Advanced settings for a visualization can be found by clicking Configure next to the visualization name.
Bar Chart settings
X-axis label | Allows you to override the default and enter a label, for example Date or Time . |
Y-axis label | Allows you to override the default and enter a label, for example Tickets or ms . |
Blocks settings
Sublabel | Choose the sublabel to be shown beneath the main block label |
Columns | Set the number of columns the blocks are displayed in |
Reset - reverts to the default settings.
Line Graph settings
Y-axis range | Auto - graph is fitted to the data automatically Percentage - shows 0-100 Fit to data from zero - shows from 0 to the data maximum Custom - allows you to specify the min and max |
Data points | This shows where the data points are on the line. Useful to identify missing points, or detail for changing data. |
Shading | Adds shading below each line. |
Scalar settings
Source Column | Choose the column to be used. The default is auto , where the column is chosen by the visualization. |
Label | Enter a label, for example Tickets or ms . |
Show formatted value | This shows a simplified value. Toggle to Off to show the raw value. (On by default) |
Table settings
Sort order | Click and drag a column name to change their order. |
Hide/show | Click on the Toggle visibility eye button to hide or show a column. |
Resizing columns | Use the handle on each column of the table to change the width. Changes will be saved while in the tile editor or in dashboard edit mode. |
Filtering, grouping and sorting of the data can be configured in the data stream advanced settings.
