GitHub plugin
Monitor the Incidents, Issues and Pull Requests from your GitHub environment.
This plugin imports an organization and repositories for a given organization name. You can also retrieve private repositories if you add a personal access token (optional).
How to add the GitHub plugin
Add the plugin to SquaredUp
Enter your organization name.
Optionally, provide a personal access token to retrieve private repositories.
Plugin access levels
Access Level:
Click Save.
