GitLab plugin
Monitor the CI/CD metrics from your GitLab environment.
How to add the GitLab plugin
To create an API token key:
Access a GitLab account with access to the target projects.
Navigate to https://gitlab.com/-/profile/personal_access_tokens.
Ensure the access is at least
read_api
andread_repository
. Please note,read_user
andread_registry
are optional.Click the Create personal access token button.
Copy the provided API token.
Now use the API token to configure the plugin in SquaredUp Cloud:
Display Name:
Instance URL:
Enter a URL if you wish to use your own instance of GitLab.
If you leave this section blank, https://gitlab.com will be used by default.
API Token:
Paste the API token in here.
Plugin access levels
Access Level:
Click Save.
Using the GitLab plugin
Data Streams
There are two types of data streams available for this plugin:
Data streams installed with the plugin
A configurable data stream, see GQL Query
Using Configurable data streams with the GitLab plugin
GQL Query
The GitLab plugin allows you to set up configurable data streams for any kind of GQL query. If you need help using GQL, please refer to: GraphQL
Scope to an object that supports a GQL query.
Select + GQL Query from the data stream list.
Enter a Display Name for the new data stream.
Query:
Enter a GQL query.
RowPath:
Optional, focus on results within the GQL query. Target on the array of data that you want to display. For example:
projects.nodes
.Click Save.
This example query shows you how to get the details about the current user, the groups it has access to and the project IDs in those groups.
query{
currentUser{
groups{
nodes
projects {
edges {
node {
id
name
fullName
id
name
id
You’ll need to inform the cloud platform where the rows start. It must be a value returned as an array, such as edges
(in the above example) or nodes
You can use mustache to alter the query with values from the scope.
A mustache parameter is a dynamic value, the actual value will be inserted from the properties of the object(s) in scope.
This data stream supplies scoped objects individually for mustache parameters. When there are multiple objects in scope this plugin will send the query multiple times, once for each object. The results are then displayed together, for example in a single table.
You can use properties of objects and write them in between curly braces e.g {{name}}
to use them as mustache parameters. Whenever you use mustache parameters, you need to use a scope of objects that contain the property you're referencing.
For example, if objects of type "host" have a property called name
, you can use {{name}}
. This will resolve {{name}}
to the value of the name property of the different "host" objects used in the scope.
