Web API
This allows you to query data from third-party APIs and present that data on a dashboard. You can add details of providers to use with the Web API data stream from Settings > Web API > Providers.
See Providers
Adding a Web API tile
Add a new tile and in the configuration scope the tile to SquaredUp
Choose the + Web API data stream.
Enter a name for this data stream. For example, Star Wars People
Select a provider from the list. For example, Star Wars.
Path Suffix: Choose the API method you want to call. For example, for the Star Wars API you can type
people
to use the People method.Row Path: Enter the response path of the property you want to turn into rows. For example, for the Star Wars API type
results
.Click Save.
Optionally, you can configure filtering, grouping, sorting etc as normal.
Configure Data Stream
Advanced settings for each data stream can be found by clicking Configure next to the data stream name.
Filtering
Data shown can be filtered according to whether data in a column equals or does not equal a specified text or numerical value. Dates can be filtered by Before now or After now, for example to show overdue orders. Text matching is case sensitive.
Group by
For example, you might Group by
service
, choose to Aggregate columnamount
with Aggregation typeTotal
, to show a table of cost per service.Which columns are available depends on the data stream you chose.
- You can also add Monitoring or KPIs, as you would for any tile.
