Cisco DNA data source
Monitor your Cisco DNA Center devices. This data source includes a small selection of data streams that allow you to view the status of devices on your network.
How to add the Cisco DNA data source
Configure and deploy an agent
Prerequisites for Agents
The Agent needs to run on a Windows machine that has access to the entry point for the on-premises data source
Make sure the Agent is able to make outbound connections on port 443 (no inbound required) to SquaredUp, *.amazonaws.com and Microsoft APIs (Azure Relay).
Parameters to replace:
-ApiKey "key"
Mandatory Replace key
Optional To run the Agent as a domain service account (for example, for the SCOM data source), provide the username as domain\username
where
key
Where
<ServiceName>
Start-Service -Name squpagent
or
Where
<DisplayName>
Add the Cisco DNA data source in SquaredUp
In SquaredUp browse to Settings > Data Sources > Add data source and search for the data source.
Display Name:
Cisco DNA URL:
Enter the URL of your Cisco DNA server.
Account Username:
Enter the username for your Cisco DNA account.
The account must have API access.
Password:
Enter the password for the API user.
Agent Group:
Restrict access to this data source?
By default, Restrict access to this data source? is set to off. The data source can be viewed, edited and administered by anyone. If you would like to control who has access to this data source, switch Restrict access to this data source? to on.
Use the Restrict access to this data source? dropdown to control who has access to the workspace:
If the user is not available from the dropdown, you are able to invite them to the data source by typing in their email address and then clicking Add. The new user will then receive an email inviting them to create an account on SquaredUp. Once the account has been created, they will gain access to the tenant.
Data source access levels
Access Level:
Click Test and save to validate the data source configuration.
Testing outcomes
Using the Cisco DNA data source
Data Streams
A data stream brings you data to answer a specific question like "What's the health state of the objects?", "What kind of alerts are coming from this data source for my servers?", "What's the average memory usage of this app?"
There are four types of data streams available for this data source:
All Devices
Shows data for all wireless controllers, all unified APs and all unreachable devices.
Unreachable Devices
Devices with an error next to Reachability Status will be shown.
All Wireless Controllers
Shows data for all wireless controllers.
All Unified APs
Shows data for all access points.
You can create new data streams that will filter on specific properties by adding that property to the datasourceconfig. You are able to do this by setting the value to the search value from the following list: hostname
, managementIpAddress
, family
, reachabilityStatus
, managementState
, location
, softwareVersion
, id
For example:
"dataSourceConfig": {
"endpointUrl": "/dna/intent/api/v1/network-device",
"hostname": "testing.global.example.com"
