Jenkins data source
This data source exposes the basic and core Jenkins components for users to visualize. You are able to index:
Projects (formally Jobs)
Controller
Plugins
Views
How to add the Jenkins data source
In SquaredUp browse to Settings > Data Sources > Add data source and search for the data source.
Display Name:
Jenkins Server URL:
Enter the URL to the Jenkins API.
Username:
Enter the username for your Jenkins account.
The account must have API access.
Password:
Enter the password for your Jenkins account.
Restrict access to this data source?
By default, Restrict access to this data source? is set to off. The data source can be viewed, edited and administered by anyone. If you would like to control who has access to this data source, switch Restrict access to this data source? to on.
Use the Restrict access to this data source? dropdown to control who has access to the workspace:
If the user is not available from the dropdown, you are able to invite them to the data source by typing in their email address and then clicking Add. The new user will then receive an email inviting them to create an account on SquaredUp. Once the account has been created, they will gain access to the tenant.
Data source access levels
Access Level:
Click Test and save to validate the data source configuration.
Testing outcomes
Using the Jenkins data source
Data Streams
A data stream brings you data to answer a specific question like "What's the health state of the objects?", "What kind of alerts are coming from this data source for my servers?", "What's the average memory usage of this app?"
A single sample dashboard is included which utilizes all data streams included with the data source. It is titled Jenkins Activity and shows the status of the builds, data sources, and nodes.
There are three types of data streams available for this data source:
Data source Status
Targets the Controller for all installed data sources
data sources needing updates will be orange
Build Status
Targets one or more Projects for the status of builds
Returns completed and in-progress builds
State matches the build result with Unknown for this in progress
Node Status
Targets the Controller to return all nodes and health
Nodes reporting as offline will be orange
