Atlassian Jira Service Management data source
Monitor service desks from your Atlassian Jira Service Management environment.
Only the Jira Cloud offering is supported by this data source.
How to add the Atlassian Jira Service Management data source
In SquaredUp browse to Settings > Data Sources > Add data source and search for the data source.
Display Name:
Domain URL:
The domain for your Atlassian instance in the format
https://your-domain.atlassian.net
User Email Address:
Enter the email address of your Atlassian user account. You need to have access to that user account since you need to create an API token with the same user you entered here (see next step).
Here's how the email address (Atlassian user account) you use here influences which data will be returned:
For Confluence data source: If the user account doesn't have access to a space, the space won't be returned. If the user account has read-only access to a space, you'll get the pages in that space.
For the Jira data source: Even if the user account you use here has just read-only access to a project, the issues in that project will still be returned.
For the Jira Service Management data source: If the user account doesn't have access to any Jira Service Management service desks, nothing will be returned by the data source.
API Token:
Go to your Atlassian account, create an API token, and paste it in here. You can go directly to your Atlassian API tokens using this link: https://id.atlassian.com/manage-profile/security/api-tokens
Note: You need to create the API token with the same user account you used for the User Email Address field.
Tip: If you are using the Atlassian Confluence and the Atlassian Jira data source you can use the same token for both data sources.
Restrict access to this data source?
By default, Restrict access to this data source? is set to off. The data source can be viewed, edited and administered by anyone. If you would like to control who has access to this data source, switch Restrict access to this data source? to on.
Use the Restrict access to this data source? dropdown to control who has access to the workspace:
If the user is not available from the dropdown, you are able to invite them to the data source by typing in their email address and then clicking Add. The new user will then receive an email inviting them to create an account on SquaredUp. Once the account has been created, they will gain access to the tenant.
Data source access levels
Access Level:
Click Save.
Using the Atlassian Jira Service Management data source
Data Streams
A data stream brings you data to answer a specific question like "What's the health state of the objects?", "What kind of alerts are coming from this data source for my servers?", "What's the average memory usage of this app?"
There are two types of data streams available for this data source:
Data streams installed with the data source, see Service Desks
Configurable data streams, see Using Configurable data streams with the Atlassian Jira Service Management data source
Service Desks
Scope to the Atlassian Jira Service Management data source. A number of object types are discovered:
Customers
Organizations
Queues
Request Types
Service Desks
Once you have selected the object, a list of several data streams will be provided. For example, you can select Queues as the object type, and then select the Queue Requests data stream to bring up a table of your tickets.
Queue data streams are defined around a JQL query, timeframes within SquaredUp will not be used on Queue data steams as these provide inherent filtering.
Timeframes can be used for other object types. Some of the available data streams can be used in conjunction with the dashboard/tile timeframe to filter by date. For example, Request Type data streams could be used in the following ways:
Requests / Closed (resolution date) – use with a 30 days timeframe to show all closed requests with a resolution date from the last 30 days.
Requests / Open (created date) – use with a 7 days timeframe to show all open requests that were created within the last 30 days.
There are two types of configurable data stream available with the Atlassian Jira Service Management data source:
+AQL Query
+Insight Objects by Type
AQL Query
Scope to Jira Insight workspace and then select the desired workspace.
Select +AQL Query.
Display Name:
Enter a display name for your query.
Query:
Enter the AQL query that you want to use, for example:
objectType = "Computers"
.See Jira Service Management: AQL for more information about AQL queries.
Only the first 300 objects will be returned.
Click Save.
Select +Insight Objects by Type.
Display Name:
Enter a display name for the new data stream.
Object Type:
Select the Object Type that you want to use from the dropdown, for example:
Clients
.Only the first 300 objects will be returned.
Click Save.
